'73 TR7RV Kickstart not working when it's cold outside - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-27-2012, 12:34 PM   #1 (permalink)
Main Motorcycle: 1973 Tiger 750
jonkull's Avatar
I've been having an unusual problem the last couple of days. In the early morning when it's cold outside my kickstart will not work. It doesn't engage and just moves freely. If I leave the bike in direct sunlight for a while or try to start the engine at any point during the day when the temperature has warmed up it will work normally.
What can cause this to happen?
jonkull is offline   Reply With Quote
Old 11-27-2012, 12:42 PM   #2 (permalink)
Main Motorcycle: T140 E
maybe the bike won't want to go for a run if it's cold outside? My mate had a dog like that!
I can only assume that something is about to go, but the heat from expansion causes it to grip whereas if colder, it slipped.
It sounds weird.
It's not too hard to get into the kick-starter mech (get some cotter pins first) and a gasket if it uses one. Take a look.
i doubt it would be on the clutch side but you might be able to find the source of the problem by warming one side with a hot air gun on a cold day.
i must say that it must be flippin' hot there as I've never had something expand to that much in a UK summer
DAVE M is offline   Reply With Quote
Old 11-27-2012, 12:50 PM   #3 (permalink)
Main Motorcycle: T110 Triton
Triton Thrasher's Avatar
Kickstart easy to press down but sometimes not turning the engine is usually breakage of the thin wide spring behind the kickstart ratchet pinion. You reach it by removing the gearbox outer cover with both pedals still on it, removing the nut on the mainshaft (check that it was tight) and pulling off the outer ratchet piece, then the ratchet pinion.
When removing the cover, keep a little downward pressure on the kickstart and try to keep the big clock spring in place.
Triton Thrasher is offline   Reply With Quote
Old 11-27-2012, 06:42 PM   #4 (permalink)
Main Motorcycle: The one between my legs
Snakeoil's Avatar
Other Motorcycle: '76 Triumph T140V
Extra Motorcycle: Yes
I've had no personal experience with this, but looking at the parts diagram I tend to agree with Triton here. The thin wide springr he is talking about is actually a flat wound spring called a thackeray washer. It is probably broken or weak and when the oil is cold and thick, it is not sufficient to engage the ratchet.
I suppose the nut could have backed off, but not sure why that would only make work when warm.
Try putting the bike in gear on the center stand and turning the rear wheel to turn the tranny a bit. It might make the ratchet engage.
Check your parts book or the parts book on-line and you will see the spring. You'll have to go in there regardless so might as well pick up the required spring and have it ready.
regards,
Rob
Snakeoil is online now   Reply With Quote
Old 11-27-2012, 07:20 PM   #5 (permalink)
jonkull's Avatar
I think the cold/warm thing was just odd coincidence. I stopped home at lunchtime and kicked it over and it started right up. I let the engine warm up a bit then shut it off, tried to start it again and had the same problem I had when it was cold in the morning. At least now I have something to do this weekend.
As far as the spring goes are you talking about part #24 on the attached diagram?
'73 TR7RV Kickstart not working when it's cold outside-screen-shot-2012-11-27-at-4.17.05-pm.jpg
Old 11-27-2012, 11:19 PM   #6 (permalink)
Main Motorcycle: T140V Bonny '77
obollox's Avatar
Other Motorcycle: T120R '71
The spring is not in the case. It's located on the end of the gearbox shaft behind the pinion
that the kickstart quadrant engages into. This might help.
http://www.ebay.com/itm/AHRMA-Triump...8d7e30&vxp=mtr
obollox is offline   Reply With Quote
Old 11-28-2012, 07:59 PM   #7 (permalink)
jonkull's Avatar
Thanks for the link that was helpful. The part is #57-1250 Pinion Spring in the parts catalog in case anyone else ever has the same issue and sees this thread. I placed an order for one and will have it Friday. Hopefully when I open the gearbox on Saturday that's actually what the problem is and I'll be back to riding by Sunday.
Old 11-29-2012, 01:34 AM   #8 (permalink)
I'd have looked before ordering parts.
Old 11-29-2012, 01:37 AM   #9 (permalink)
White in a bulb means air got in. That's vibration.
If it happens a lot, you need to rubber mount the headlight, somehow.
Old 11-29-2012, 02:07 AM   #10 (permalink)
jonkull's Avatar
$3 part. If it turns out to be something else I'll have a spare spring.
Tach not working... Now Speedo not working. Road Racer Classic, Vintage & Veteran 2 06-27-2012 05:35 PM
01 790 hard cold start /cold misfire kiwiraca Twins Technical Talk 6 03-14-2010 04:34 PM
Cold Weather Riding - How Cold is too Cold? canuck3134 Classic, Vintage & Veteran 21 11-24-2009 08:19 PM
rev counter not working from cold trolkien Trophy 2 03-03-2009 05:53 AM
Cold Weather and Kickstart Troubles jonkull Classic, Vintage & Veteran 40 02-19-2009 07:09 PM
