confused about primary case oil.... - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 11-26-2012, 05:47 PM   #1 (permalink)
Main Motorcycle: my 66' Triumph 650
Other Motorcycle: 2007 Harley softail
when i first purchased my bike last year (66' TR6R) i asked the forum about what type of oil was best for primary...ATF Type "F" seemed to be the consensus. the service manual says SAE 20....and now i have been reading threads about people using the same 20/50 engine oil in oil tank and primary??? also saying that the primary oil can end up in crankcase, which if that is true, i would think using the same oil in primary would make the most sense.....can someone help clear this up for me, and tell me the best way to go? i am currently using a good grade motorcycle oil 20/50 rated at SG in the oil tank....should i use the same in primary? thanks, Rick
razman is offline   Reply With Quote
Old 11-26-2012, 06:31 PM   #2 (permalink)
Moderator
Main Motorcycle: Rickman T120
Other Motorcycle: T160,TR6
Your primary oil is separate from the crankcase and engine oil.
That was changed in 1970 by leaving out the crankshaft seal,drilling 3 small level holes to drain excess oil out of the primary,and running the crankcase breather off the primary case.'70 onward use the same shared oil in the primary and crankcase.
Light oil in the primary is better for chain life.ATF gives less clutch slippage than light engine oil.The best oil to use is type "F" ATF.It won't mix with your engine oil on a standard '66.
Mr.Pete is offline   Reply With Quote
Old 11-26-2012, 06:51 PM   #3 (permalink)
THANK YOU........i was confused/concerned....Rick
how to remove hub in primary case? razman Classic, Vintage & Veteran 16 12-04-2011 05:33 PM
primary case oil ; tigercub Classic, Vintage & Veteran 7 06-05-2010 11:28 PM
Primary case question. RetroRod Classic, Vintage & Veteran 6 05-31-2010 08:39 PM
Crank Case / Primary Chain Case - Seals Help Will71bonneville Classic, Vintage & Veteran 8 02-12-2010 01:48 PM
Primary chain case crazypierre Classic, Vintage & Veteran 13 02-19-2006 12:31 PM
