Steering Bearing question - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.com SportbikeTrackGear
Old 11-24-2012, 09:07 AM   #1 (permalink)
Main Motorcycle: '77 T140V
I'm starting my winter work on my 77 T140v, and found that the steering bearings are badly in need of replacement. They were tapered roller type at one time, but the bottom one was nothing but a few rollers and LOTS of rust.
The bottom race is toast, and there's no way to get anything on it to drive/pull it out. There's also very little race visible to work with on the top. There is a good bit of metal visible that is either a machined landing, or maybe the spacers in the parts book. I don't have parts yet to compare.
Can someone clear this up for me? I don't want to start beating on things and end up with a bigger problem!
Thanks
Smokin' Joe is offline   Reply With Quote
Old 11-24-2012, 11:23 AM   #2 (permalink)
Main Motorcycle: T140 E
http://classicbike.biz/Triumph/Repai...hop-Manual.pdf
Have you got the forks right off?
you should be able to punch the bearings out from the other end
DAVE M is online now   Reply With Quote
Old 11-24-2012, 11:33 AM   #3 (permalink)
Yes, front end completely disassembled. Not enough race left to get a punch on.
Old 11-24-2012, 12:59 PM   #4 (permalink)
You could try an expanding rawl type bolt.
Tighten it up so it grips the inner, where the fork stam would be, and whack the bolt from side to side, or use a tube on it like a slide hammer?
Old 11-24-2012, 01:14 PM   #5 (permalink)
TBS
carefully cut it in two with a dremel.
TBS is offline   Reply With Quote
Old 11-24-2012, 07:36 PM   #6 (permalink)
Main Motorcycle: Triumph T140 & TR7
Other Motorcycle: Guzzi T3
Extra Motorcycle: Another Guzzi T3
tbs'S SOLUTION WORKS IF YOU'RE VERY CAREFUL - HAD TO DO THIS ON A BIKE ONCE. lATER, FACED WITH THE SAME PROBLEM, i HAD A FRIEND WELD A BAR (JUST AN OLD BOLT THE RIGHT LENGTH) ACROSS THE OUTER RACE SO i HAD SOMETHING TO BASH. wORKED A TREAT, BUT DOES DEPEND ON EITHER HAVING WELDING GEAR AND KNOWING HOW TO USE IT, OR HAVING A FRIEND WHO DOES!
Sorry for capital letter shouting - only just noticed.
JohnA is offline   Reply With Quote
Old 11-25-2012, 12:28 AM   #7 (permalink)
Main Motorcycle: the ones that run
Other Motorcycle: The ones that don't run
Extra Motorcycle: Lots
Run a bead of weld on the face of the race, all the way around. When the race cools it will fall out on its own, no punches or pullers necessary.
Robbie
Rubone is offline   Reply With Quote
Old 11-25-2012, 08:15 AM   #8 (permalink)
Main Motorcycle: t140
Rubone has the answer, worked for me!
wolfwolf is offline   Reply With Quote
Old 11-25-2012, 02:34 PM   #9 (permalink)
Tiger Dale's Avatar
Robbie
Nice
Tiger Dale is offline   Reply With Quote
Old 11-29-2012, 07:51 PM   #10 (permalink)
Thanks to all for the responses. I've read about the welding trick for rusted races on boat trailers. I'm concerned that the heat might distort the tube and cause the new bearings not to seat properly. Maybe I'm paranoid, but I can't replace the frame easily. I thought of the dremel idea, and got a couple of dental diamond bits. I think I'll have a go with it this weekend. Supposed to be warm here. so I won't have to heat the garage...
Steering Head bearing question. Wombat Hinckley Classic Triples 5 08-30-2010 03:25 PM
Steering bearing NJTiger Classic, Vintage & Veteran 4 10-12-2009 06:26 PM
Steering bearing substitute? blackfly911 Hinckley Classic Triples 9 04-29-2008 12:53 PM
Steering head upper bearing question SARUNAS Hinckley Classic Triples 0 11-24-2005 04:54 AM
Steering Bearing msparks Sprint Forum 2 04-26-2004 10:20 AM
