| Classic, Vintage & Veteran For Coventry and Meriden Models. Anything pre-Hinckley goes. |
11-24-2012, 05:26 PM
#11 (permalink)
Pole Position Main Motorcycle: The one between my legs
Posts: 3,757 Other Motorcycle: '76 Triumph T140V Extra Motorcycle: Yes
I would doubt that you would be able to get a socket on the nut due to lack of overhead clearance.
You can torque nuts with a common box wrench (ring spanner). Just use a spring scale or digital strain gauge to pull on the other end. Torque is mass x distance so just just measure the wrench where you willl place the spring scale and do the calc.
If you are using a combination wrench and the open end where you will hook the scale is 8 inches from the center of ring end, then you just mutiply 8 inches x the lbs you read on the scale for the torque reading. So if you want to torque nuts to 200 inch-lbs, 200/8 = 25 lbs. So 25 lbs is what you want to read on the spring scale.
If you want to measure in foot lbs, 200 inch lbs is 16.67 ft-lbs.
So take your 8 inches, divide it by 12 to get the fraction of a foot, which is .667 foot. Now divide 16.67 fl-lbs by .667 ft and you get 24.98 which rounds to 25 lbs, which is the force you read on the scale for foot lbs. Notice it is the same mass, 25 lbs in both cases because 200 in-lbs = 16.67 ft-lbs.
The other key point is always pull the scale 90 degrees or perpendicular to the axis of the wrench.
Got it?
regards,
Rob
11-24-2012, 05:36 PM
#12 (permalink)
Powerbike Main Motorcycle: '74 T140V Chop
You know, I've never even thought about it that way... Damn good point!
I've always just used a torque wrench!
11-24-2012, 11:28 PM
#13 (permalink)
Measuring torque on used hardware is an approximation at best IMHO. Variables such as dirt, damaged threads, oil or other lubricants all vary the friction which varies the amount the bolt is stretched for a given torque read. Add to that the accuracy of the torque wrench, not to mention how well it is calibrated all add to the variability. My experience with spring scales is they are pretty accurate. They are at least accurate to within 1 lb and that's all you need. So using a spring scale might even be more accurate than using a torque wrench.
There is a used tool shop near me and he has a torque wrench calibrator bolted to his wall. Never did ask him were it came from, but it is a pendulum that swings thru 90 degrees with a weight on the end. The scale is an arc graduated in in-lbs and foot-lbs I believe. It's been a while since I've used it. I've brought a couple Taiwan click type torque wrenches in there and calibrated them. Then I ran them thru their range and they were remarkably accurate.
regards,
Rob
11-25-2012, 07:40 AM
#14 (permalink)
SuperStock Main Motorcycle: 73 TR7RV Tiger W/2 carb's
Posts: 240 Other Motorcycle: Feet............or crawl Extra Motorcycle: Mtn Bike - GT Zaskar Team
Originally Posted by Mr.Pete
Google-search "12 point nuts".Summit Racing offers a 10-pack ,chrome-moly with black-oxide finish,made by ARP.A little over $13 for 10,or about the same unit price for single nuts.You would need to zinc plate them,or use silver paint.
The also offer them to suit a 1/2" or7/16" wrench.You need 1/2" wrench size,and 3/8" x 24 tpi thread.
Total bummer, I wish I had read this post before, I'm going downstairs right now to do the upper end on my TR7RV, as well as new ring's, base gasket - the works.
Would love to replace the base nuts with stainless (another time).
Bill
An Irishman on a Limey
11-25-2012, 07:49 AM
#15 (permalink)
regards,
Rob
Be very careful as to the light settings on a click type torque wrenches, got a brand Click Type (always used old school) new one from where I work, used it a few times on wheel axle nut, head bolts, no problem, when I did the front wheel bearings - and torqued the nuts for the caps - stripped one clean - not the nut - but the entire stud, now using a locktite to hold.
Crap
11-25-2012, 10:24 AM
#16 (permalink)
Grand Prix 250 Main Motorcycle: T140V Bonny '77
Posts: 80 Other Motorcycle: T120R '71
Two or three open ended spanners held on to the hex nut can help
prevent rounding it off.
11-25-2012, 10:58 AM
#17 (permalink)
Pole Position Main Motorcycle: T140 E
Posts: 3,485 Other Motorcycle: 56 Plunger Tatty Cub Extra Motorcycle: CZ winter bike
It's ages since I did the base nuts but don't think they were torqued.
I am pretty sure that H Hancox just did them "tight" if you use the correct spanner, then you're limited as to how hard you can tighten them anyway.
I have 6 sided stainless on mine ( I think!) the bike is in the garage and it's cold.
11-25-2012, 11:02 AM
#18 (permalink)
Surely if you were torquing them to the correct setting, no matter what type of torque wrench it is, if it strips then the stud needed replacing anyway?
Yeah, where I did my apprenticeship we had a test bench for torque wrenches that were calibrated every 6 or 12 months. I have a Norbar torque wrench that maxes out at 50Nm or something (ideal for Triumph engine, that's why I bought it). I'm going to have somebody I know who still works where I used to to check my torque wrench for accuracy before building.
As far as I can remember (without looking) the Triumph book states torque figures dry. Using lubricant on the threads could cause you to over tighten them considerably.
11-25-2012, 06:20 PM
#19 (permalink)
Formula Extreme Main Motorcycle: 2001 Trophy 1200, T509
Posts: 527 Other Motorcycle: Norton Commando MK 3 Extra Motorcycle: 1968 BSA Thunderbolt
Tighten it up' 'till it snaps or strips, back it off a half turn....perfect!
11-26-2012, 02:30 AM
#20 (permalink)
Haha! If only there were a like button. Facebook is spoilt.
