79 Bonneville Front seals - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.comSportbikeTrackGear
Old 11-21-2012, 09:37 AM   #1 (permalink)
jrc
Main Motorcycle: Triumph America
Other Motorcycle: HD Softail Springer
Extra Motorcycle: BMW LT 1200
I am replacing the front seals. I have removed the allen bolt in the fork leg. From what I see in the manual and read in this forum the bottom part should now separate from the tube. Is this correct? I dont see any clip or anything else aroud the seal. It looks like just a protective plate on top of the seal.
How much if any force is necessary to separaate the bottom from the tubes? Does any one know of any fastners I have missed to separate them?
Thanks for the help.
jrc is offline   Reply With Quote
Old 11-21-2012, 09:56 AM   #2 (permalink)
Main Motorcycle: '01/'06 Sprin/tona RS
kredge's Avatar
Other Motorcycle: '79 T140E
There should be a circlip on top of the fork seal unless the seals were previously replaced with older ones that fit 650's. I think the earlier ones are too thick to allow room for the circlip so it's just left off.
Once you've removed the circlip you should be able to seperate the fork slider from stanchion. I think it's the inner bushing that actually pops the seal out as it passes by so think of the force as if you're using a slide hammer.
Did you remove that protective plate?
kredge is offline   Reply With Quote
Old 11-21-2012, 10:37 AM   #3 (permalink)
jrc
No I havent removed the protective plates. I didnt see a clip holding them in and didnt want to start prying on anything until I got some advice.
Old 11-21-2012, 11:00 AM   #4 (permalink)
Main Motorcycle: 1982 TSS + 2011 Tiger 80
epynt1050's Avatar
Other Motorcycle: 82 TR65, 69 T120 73T100R
Extra Motorcycle: 08 Street Triple, 1913 "A
A couple of points
1) the earlier, thicker seals work better and are less likely to leak. They are just a push fit.
2) there is a Dowty seal in the bottom of the fork leg. The allen screw fits through it and it forms the lower seal. It should be replaced with a new one. Note:- it sits in a recess in the bottom of the leg and care must be taken to ensure that it is properly located before you put the allen screw back in. Once located, put the stanchion back into the lower leg and push down to the bottom of the leg. Only then insert the allen screw and tighten.
epynt1050 is online now   Reply With Quote
Old 11-21-2012, 11:10 AM   #5 (permalink)
Main Motorcycle: 1979 T140D Special
Other Motorcycle: 1978 T140E
The earlier '79 T140's didn't have the circlips. Instead they had a thicker interferance fit washer holding the seals in place. The later '79 T140's did have the circlips holding thinner washers in place. Lots of people will tell you that the older seals are better, but I don't think that there is anything wrong with the later style seals. I've got 5 T140's in the garage, all with the later seals and none of them leak.
Cybersausage is online now   Reply With Quote
Old 11-21-2012, 01:06 PM   #6 (permalink)
epynt1050's Avatar
I understand that the thinner seals used by Triumph were fine. I have been advised by a couple of the main spares suppliers inc Reg Allen that unfortunately the replacements for the thinner seals now available do not work as well. I have had to go back to thicker seals on both my T140 and my TR65.
Old 11-21-2012, 02:51 PM   #7 (permalink)
Main Motorcycle: Triumph T140 & TR7
Other Motorcycle: Guzzi T3
Extra Motorcycle: Another Guzzi T3
Interesting re seal comparisons. But back to the question - surely, whether fitted with newer type seals or the older type, once the allen screws are removed from the bottom ends, the sliders should just slide off without the need for any particular force?
As for the 'bushings' - maybe I've missed something re. the post-1980 models, but as far as I know Triumph OIF forks never had any bushes?
JohnA is online now   Reply With Quote
Old 11-22-2012, 05:01 AM   #8 (permalink)
Main Motorcycle: T140 E
DAVE M is online now   Reply With Quote
Old 11-22-2012, 04:55 PM   #9 (permalink)
The Plewsy video posted by Dave M shows how to do it. There are no bushes, nothing 'pushes' or 'pops' the seals out, and there's no need for any slide-hammer action! Getting the sliders off is easy but getting the old seals out is not so easy - you're never using them again so be generous with the heat.
Old 11-26-2012, 08:33 AM   #10 (permalink)
The only one I had leak was the older type fitted by Reg Allen. I replaced them with the newer type and they have been fine since.
Front Fork Seals fnscotsman Twins Technical Talk 5 09-13-2012 05:33 PM
wanting to replace seals on front forks...big job?? razman Classic, Vintage & Veteran 42 04-14-2011 06:05 PM
Front Fork Seals... need help... Backlash Daytona Deliberations 9 08-15-2007 04:10 PM
Fork seals and front suspension upgrade raj76 Speed Triple Forum 0 03-09-2005 01:08 AM
oil leak , seals , front sprocket durkster Hinckley Classic Triples 2 01-13-2005 12:09 PM
