1972 500 Front of Motor Oil Leak Help!!! - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 14 (permalink) Old 11-20-2012, 11:10 PM Thread Starter
Main Motorcycle: 1966 Triumph Daytona 500
Hello, Thanks for all your help guys!! Unbelievable what technology can do.
I have a new problem. After 2-3 miles of tuning after rebuild(not engine), I have developed a small oil leak on the front of the motor. It seems to be coming from a bolt just above the exhaust outlet on the left side of the motor. A loose exhaust nut has sprayed the oil all over my motor. It smells good, but I could do without the the smoke. The bolt on the other side in the same position seems to have a washer, where this one does not. I am going to look in my manuals tonight, but I thought I'd start here. Any Suggestions???
BritSpeed is offline
post #2 of 14 (permalink) Old 11-20-2012, 11:43 PM
Main Motorcycle: 1978 Bonneville T140V
Morris the Cat's Avatar
Good news/ Bad news!
Good news is you have oil pressure!
Bad news is it shouldn't be from the exhaust.
Check out the oil pressure switch while your at it.
http://farm3.staticflickr.com/2880/9419068358_fe3bbd6508_t.jpg
Morris the Cat is offline
post #3 of 14 (permalink) Old 11-20-2012, 11:54 PM Thread Starter
It coming from a bolt above the exhaust. A loose exhaust nut has sprayed it around. Thats how I found it.
post #4 of 14 (permalink) Old 11-23-2012, 12:21 PM Thread Starter
I do believe I have a head gasket leaking. Possibly a gasket under the cylinder head. Why not do a top end rebuild. I've always wanted too. Thanks to Lunmad, I am not scared.
post #5 of 14 (permalink) Old 11-23-2012, 01:28 PM
Main Motorcycle: T140 E
Is it the pushrod tube seal?
DAVE M is offline
post #6 of 14 (permalink) Old 11-23-2012, 03:33 PM
Main Motorcycle: 1971 t120r
rambo's Avatar
Other Motorcycle: triumph rocket 111
Extra Motorcycle: BSA Spitfire
If its a headgasket leak,put your hand near it and see if you can feel a gas leak.Alternatively,spray it with penetrating oil and see if it blows it around
rambo is offline
post #7 of 14 (permalink) Old 11-26-2012, 10:52 AM Thread Starter
BOTH!!! Push rod tubes are leaking and head gasket. Guess I should order that gasket set.....fun, fun, fun!!! A fin on my head has cracked off fairly close to one of the head bolts. I don't know if it's salvageable?? Anyone have an extra 500 head lying around??
post #8 of 14 (permalink) Old 11-26-2012, 10:53 AM
It'd be cheaper to get the fin fixed
DAVE M is offline
post #9 of 14 (permalink) Old 11-26-2012, 10:56 AM Thread Starter
post #10 of 14 (permalink) Old 11-26-2012, 11:11 AM
If you have the bit, a decent welder can fix that.
if not, it's harder, but do-able
http://www.britbike.com/forums/ubbth...&Number=366265
DAVE M is offline
What's a stepper motor, and why does it have a vacuum leak? AaronB Daytona Deliberations 6 11-03-2012 06:16 PM
1972 bonneville front drum brakes TCEd Classic, Vintage & Veteran 9 06-04-2012 12:00 PM
1972 T120R Motor Rebuild Rapidroy The Welcome Center 1 02-08-2012 10:51 PM
Oil leak behind starter motor?? Motley Air Cooled Twins Talk 13 08-07-2006 05:12 PM
