High-power alternator rotor - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
Old 11-20-2012, 12:07 PM   #1 (permalink)
Main Motorcycle: VFR
Other Motorcycle: T100S
I spotted that Tri-Cor are selling high-power Sparx alternator rotors so bought one to test. I compared the Sparx to a new Wassell and an original Lucas rotor.
I tried them in two stators, one an unnamed stator that is usually advertised as suitable for Royal Enfield and made in India. The second stator was a Lucas 47205A two wire 120W nominal output.
The voltages are AC on my meter and I have used a 1ohm load at 3000 RPM.
Unknown..Lucas.....12.2v.....149W
.............Wassell....12.8v.....163W
.............Sparx......14.9v.....222W 59W extra
47205A...Lucas......10.8v.....117W
.............Wassell....11.0v.....121W
.............Sparx......13.1v.....171W 50W extra
50 Watts extra power is well worth having in anybody’s book. The rotor costs just under £80.
DerryUK
'69 T100S being rebuilt - very s-l-o-w-l-y
VFR800 VTEC
DerryUK is online now   Reply With Quote
Old 11-20-2012, 12:50 PM   #2 (permalink)
Main Motorcycle: 1971 t120r
Other Motorcycle: triumph rocket 111
That looks impressive.I buy mine at autojumbles for £10 though.If i ever buy a new one,this is helpful info.Cheers
rambo is offline   Reply With Quote
Old 11-20-2012, 02:32 PM   #3 (permalink)
Main Motorcycle: '74 T140V Chop
That's awesome! I have been thinking about going down the Sparx rotor route for a while now as I want to run Tri-Spark with no battery.
Quite surprised the rotor actually is that good. Nice one!
loxx101 is offline   Reply With Quote
Old 11-20-2012, 02:57 PM   #4 (permalink)
<Quite surprised the rotor actually is that good>
Agreed, plus of course if you have a three-phase stator you'll squeeze even more power out of it.
DerryUK
VFR800 VTEC
Old 11-21-2012, 04:55 AM   #5 (permalink)
I have just been given a three phase alternator as well. Happy days!
For the money, it sounds like replacing my rotor is a sterling idea.
Old 11-21-2012, 05:34 AM   #6 (permalink)
As has been said to me elsewhere these rotors won't do a standard zener any good, you need a proper aftermarket rec/reg.
DerryUK
VFR800 VTEC
Old 11-21-2012, 06:14 AM   #7 (permalink)
Yeah, I found a cheap new one on an eBay shop.
It seems like a worthwhile cheap improvement for reliability.
Old 11-21-2012, 08:26 AM   #8 (permalink)
Main Motorcycle: Triumph T140 & TR7
Other Motorcycle: Guzzi T3
Extra Motorcycle: Another Guzzi T3
Could the poor performance of the original Lucas rotor be due to it having lost some of its magnetism? And would the improved performance of the Sparx item be due to stornger magnetism that they've somehow managed to build in? I can't think what else could be changed on a rotor to make any difference to output (but then I am not any kind of electrician!)
JohnA is online now   Reply With Quote
Old 11-21-2012, 09:17 AM   #9 (permalink)
Well they claim it is a stronger magnet, yeah. I imagine a new lucas rotor would be substantially better than old.
Old 11-21-2012, 12:47 PM   #10 (permalink)
<Could the poor performance of the original Lucas rotor be due to it having lost some of its magnetism>
The Lucas rotor generates 117W with the 120W stator which is pretty close. I have measured worse than this with rotors. See here ...
http://www.scribd.com/doc/102021181/Lucas-Stator-Log-4
As Lox says it's down to stronger magnets in the Sparx rotor. Like a lot of sellers though they just say stronger, more powerful etc. which is pretty meaningless. Even saying 200W doesn't really mean a lot unless you know the voltage and load it was measured with.
DerryUK
VFR800 VTEC
Wassal alternator rotor loose on key Steve69 Classic, Vintage & Veteran 2 03-08-2012 05:04 PM
I need an alternator rotor shaughnessy Speed Triple Forum 1 11-19-2010 01:18 PM
Loose alternator rotor Robert.v Classic, Vintage & Veteran 13 02-08-2010 12:28 PM
Alternator Rotor Tool Wolf Dreaming Twins Technical Talk 4 01-30-2010 07:38 PM
alternator rotor crank nut T140v KENT PLUMS Classic, Vintage & Veteran 4 10-13-2008 09:06 AM
