Originally Posted by trophy69
The plain washers are 97-1656, the others (both sides) are what were on my 69 t100c. I like the tight seal and cork layer. Anybody what they are and where to get?
I don't see the cork piece in your photo. But from the description and what I see there, you are talking about the spring abutments and the cork seal above them. They are in the parts manual.
You should not have to replace the abutments. Just the cork seals, which I'm not sure do very much other than provide a cushion between the bottom of the yoke and the abutment (spring seat would be what us 'Muricans would call it).
I made my own cork seals by gluing two layers of rubberized cork gasket material together with contact cement to get the correct thickness and then made the proper size hole punches from a piece of exhaust pipe (OD) and tubing (ID) and punched them out on my press.
regards,
Rob
