| Classic, Vintage & Veteran For Coventry and Meriden Models. Anything pre-Hinckley goes. |
11-18-2012, 09:18 PM
SuperSport Main Motorcycle: 1999 T'Bird Sport
Posts: 1,323 Extra Motorcycle: 1977 T140
T140 Crankshaft Balance
Completed on a Sunnen DCB-750 operated by an expert.
11-18-2012, 09:53 PM
Moderator
Moto Grand Prix Main Motorcycle: Rickman T120
Posts: 2,931 Other Motorcycle: T160,TR6
Interesting that they added 3 gms/cylinder for oil.
The 74% spec from Triumph was with a dry crankshaft.There would certainly be more than 6 gms of oil normally in the sludge trap,probably more than 20 gms.
It looks as though it would have been balanced closer to 65%,when it left the factory.It's not unusual to find that,yet the engines still run smooth.
A higher balance factor decreases vertical imbalance and increases horizontal imbalance,but the imbalance loading on the crank increases.Overall smoothness and comfort to the rider doesn't seem to change.
11-18-2012, 10:23 PM
Crank Balance
Understand that. I believed that going this far it would be a good idea to have the crank balanced, not ever having riden the bike (Barn find) I guess I will never know wether or not an improvement has been made.
11-22-2012, 09:42 AM
Grand Prix 125 Main Motorcycle: t140
I would assume you will be ballancing the rods and pistons also, or that was a waste of time and money?
11-22-2012, 01:15 PM
Balancing
And I would assume that you read the above attachments?
Reason: Spelling?
11-23-2012, 06:47 AM
I was refering to EACH piston. I see that all parts were weighed and used to ballance the crank, but did you also make each piston and rod weigh the same?
Im not trying to be a smartass here, really just courious.
I usuall just throw the motor together and hope for the best!
11-23-2012, 01:48 PM
Powerbike Main Motorcycle: '74 T140V Chop
In a way I wish I had done that now. My engine is heading for a couple of grand now. I guess it'll run amazingly but how much better I'm not really sure!
Would have cost £200 if I had done a basic job on it!
11-24-2012, 08:34 AM
yep, once you start down the road with the best of everything its hard to draw the line where to stop.
Untill your pockets are empty!
Good luck with the build.
11-25-2012, 06:08 PM
Dynamic Balance
I guess, given that the balance was undertaken by an expert (not Me) the job has been done correctly. Time will tell!
