A little bit of advice as to how to get these out. - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 11-19-2012, 11:20 AM   #11 (permalink)
Main Motorcycle: T140 E
Not that I would, but you can buy replacement non allen headed screws if you are worried about authentic looks. Me, I'm more worried about getting a good seal and removal of the screws when I need to
DAVE M is offline   Reply With Quote
Old 11-19-2012, 03:14 PM   #12 (permalink)
Main Motorcycle: 1978 Triumph 750 Tiger
Other Motorcycle: Trident 900
Extra Motorcycle: 64 BSA B40 SS90
I had some stubborn crosshead screws on my B40, I used a cordless drill as a type of impact driver by using the torque settings.
Make sure all the crud is cleaned out of the screw heads use a brand new pozi bit directly in the chuck ( the magnetic holders allow the bit to rock ) set the drills torque setting to it's min setting. Hold the drill firmly and square in the screw, give the drill a spin and then click slowly up the torque settings. The pluses from the drill should free the screws off. Obviously if the screws don't budge and the torque setting is getting quite high stop however this method worked on all my tough screws.
tommytiger is online now   Reply With Quote
Old 11-21-2012, 06:03 PM   #13 (permalink)
Main Motorcycle: 1952 BSA A10 Plunger
Other Motorcycle: 1958 Tiger T100
When you replace the cross headed screws with allan screws, don't be tempted to overtighten them when you do them up. It's very easy to do, and you'll end up damaging the threads in the relatively soft alloy of the casings. That's the only advantage (apart from keeping the looks original) of the cross heads, I've replaced them at every opportunity with allan headed screws on every bike I've owned.
shabashow is offline   Reply With Quote
Old 11-22-2012, 09:48 PM   #14 (permalink)
Main Motorcycle: 1971 Triumph Bonneville
leylandauto's Avatar
Other Motorcycle: 67 MGB
I noticed that Lowes now sells Pozidrive bits.
leylandauto is offline   Reply With Quote
Old 11-23-2012, 12:01 AM   #15 (permalink)
Main Motorcycle: 1959 Triumph Bonneville
bushybester's Avatar
Other Motorcycle: 2nd 1959 Triumph Bonne
Extra Motorcycle: 1982 R100RS BMW
Originally Posted by Morris the Cat View Post
The correct bit is a posi-driv .
With the right one,take a plastic head shock hammer and sharply tap thru the screwdriver to loosen the threads.
Looks like a standard phillips head bit isn't
Mine were changed over to allen type fittings.
You can also dip the screw point in a bit of valve grinding paste if the tip doesn't fit perfectly. It will give you extra grip. The important thing here is the point must fit snugly, put pressure on it in anti-clock wise to release it, and then give it a sharp smack on the screw driver head.
bushybester is offline   Reply With Quote
Hello! Advice? DCOURTS The Welcome Center 1 11-30-2010 11:02 PM
Looking for advice Shotime Triumph, Models & Dealers 13 02-21-2008 05:58 PM
I Need Advice! NewMetal T3 Sport / Touring Forum 4 02-16-2008 02:02 AM
I need some advice merlotlover Twins Technical Talk 7 04-12-2007 07:12 PM
Any advice? Freakazoid84 Sprint Forum 2 04-30-2006 08:45 AM
