'65 T120 Clutch Hub Locking Up - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-18-2012, 04:50 AM   #1 (permalink)
Main Motorcycle: 1965 Triumph Bonneville
Novice replacing the primary chain and clutch plates on my 1965 T120. Everything I read says that I would need a puller to remove the drums but everything came off easily without a puller. On re-assembly, the inner drum locks up with the outer drum when I tighten the nut. Not torquing it, just tightening a bit. I took everything apart and re-assembled. Looks like everything is assembled correctly. Thrust washer is in behind the the outer drum, copper side out. All 20 rollers correctly positioned. Shaft washer in place. I'm wondering now if the nut was not torqued but just snugged up with locktite when I took it apart. Are the drive center and spider tapered to keep the inner drum from travelling too far back? What is supposed to keep the drums from binding together? Any help appreciated
siglass is offline   Reply With Quote
Old 11-18-2012, 06:52 AM   #2 (permalink)
Main Motorcycle: 1966 T120R
Other Motorcycle: BSA B50SS
Extra Motorcycle: Yamaha XT600 43F
If the clutch screws are incorrect so they protrude past the rim of the clutch centre or if they twist and become misplaced during assembly they will jam between the clutch centre and the drum and lock everything up when the nut is tightened.
ebsbury is offline   Reply With Quote
Old 11-18-2012, 08:47 AM   #3 (permalink)
Moderator
Main Motorcycle: Rickman T120
Other Motorcycle: T160,TR6
Good point with the spring studs.If they're not free to rattle,they could be misplaced.
The only other thing I would suspect is the thrust washer dropping out nof position.
Mr.Pete is online now   Reply With Quote
Old 11-18-2012, 02:47 PM   #4 (permalink)
Just made a sign for the garage wall reminding myself to look for the obvious. Appreciate both replies. Both were right on. One of the screws was turned and binding up. Drum is now torqued down and rotating freely. Thank you for the quick feedback.
Steve
Old 11-18-2012, 02:52 PM   #5 (permalink)
Main Motorcycle: Tiger Cub 1957
Other Motorcycle: T140 1982
Are you fitting a new thrust washer?
I found a new un locked up my clutch. When I replaced the original there was no problem.
The difference in thinkness between the two was under 2 thou. I think the nub of the problem was the chamfer worn on the inside diameter of the old washer; the new one lacked this and was binding.
You might find the same problem if you were fitting the old one back to front.
PS
I see you have it sorted, well done.
Doug748 is online now   Reply With Quote
Old 11-19-2012, 12:59 AM   #6 (permalink)
I used the old thrust washer. It was in good shape. Didn't notice a chamfer. Thanks for your input.
Clutch locking tool? Doug748 Classic, Vintage & Veteran 8 12-23-2012 11:43 AM
Hydraulic clutch T120 -69 Zozan Classic, Vintage & Veteran 2 05-10-2010 02:22 PM
1972 T120 New Clutch Savannah Bill Classic, Vintage & Veteran 10 12-28-2009 05:52 PM
Clutch Drum Locking Tool digdug72 Classic, Vintage & Veteran 1 09-08-2008 08:52 PM
