which 0-ring is best for amal concentrics? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-16-2012, 12:27 AM   #1 (permalink)
Main Motorcycle: my 66' Triumph 650
Other Motorcycle: 2007 Harley softail
i'm looking to get new o-rings to mount carbs to manifold...i've noticed that some are referred to as "thin" and some "thick"......these carbs are new 930's. is there a benefit of one o-ring over the other? which is correct? thanks, Rick
razman is offline   Reply With Quote
Old 11-16-2012, 03:55 AM   #2 (permalink)
Main Motorcycle: 1966 T120R
Other Motorcycle: BSA B50SS
Extra Motorcycle: Yamaha XT600 43F
Use the thin type, 622/101. I have them on my 66 bonneville and they work fine. The thicker type is used on 650 and 750 Bonnevilles after 1970 with shouldered studs, rubber washers and cup washers to insulate and partly flexibly mount the carbs.
ebsbury is offline   Reply With Quote
Old 11-16-2012, 12:57 PM   #3 (permalink)
thank you!!
Old 11-16-2012, 02:25 PM   #4 (permalink)
Main Motorcycle: 1970 Bonneville
Thicker ones were definitely used on '69 and '70 Bonnevilles and are recommended for those years. I can't say what would be best on a '66 although I don't think a 930 was stock for that year. Perhaps the inlet manifolds were updated. If so, the thicker ones might be more appropriate.
henryanthony is online now   Reply With Quote
Old 11-16-2012, 05:08 PM   #5 (permalink)
well, on my 66', the manifolds look to be pretty much stock, but these are brand new 930 Amals, the slides are sometimes a tad bit slow to return to idle, ( i know you have to be careful about over-tightening the bolts) but i just wondered if the thicker o-rings would be more "forgiving" and allow the slides to return smoother....could be partially in the cables too....what's the best way to lube the throttle cables, (i have two separate cables, with adjusters near the throttle at the handlebars) thanks, Rick
Old 11-16-2012, 06:24 PM   #6 (permalink)
Moderator
Main Motorcycle: Rickman T120
Other Motorcycle: T160,TR6
The thick O-rings are an improvement,but you need self-locking nuts if you use them.You have to be careful not to over-tighten them and bend the flange.There's normally a gap at least 0.045" between the flanges,with the thick O-ring.
It is all easier if you use the later manifolds.
If the slides are sticking,your flanges may already be bent.
Mr.Pete is online now   Reply With Quote
Old 11-16-2012, 07:49 PM   #7 (permalink)
I have found that with the slim export tank and the twin cable twist grip that the carburetters are much more affected by the length and run of the cables which can make the slides slow to shut. But I really like being able to adjust the cables without taking the tank off. I have fixed it the problem for now with stronger springs until I can make some longer cables. I would lubricate your cables and check they are mounted as freely as possible under the tank - and not caught between the tank and the head steadies. You can buy cable lubricators - they are cheap on e-bay or you can use the trad method of creating a funnel out of a plastic bag around the top of the cable and hanging the cable up while oil drains through it. You'll need to tape up the adjusters first!
Triumph used the thicker O ring in conjunction with shouldered studs and rubber washers to rubber mount the carburetter. The reason was to attempt to insulate the carburetters from vibration and reduce fuel frothing at sustained high speeds. The resulting air gap might make the carbs run cooler but you can achieve the same affect with a phenolic spacer with less chance of distorting your flanges.
Amal Carb rubber ring gaskets - needed? Kev_England Classic, Vintage & Veteran 30 06-20-2011 02:47 PM
amal carb to manifold o-ring; tigercub Classic, Vintage & Veteran 2 02-05-2010 11:27 PM
Amal carb "O" ring question. bushybester Classic, Vintage & Veteran 2 01-25-2010 04:35 AM
Amal concentrics Nzbiker Classic, Vintage & Veteran 4 02-29-2008 09:00 PM
