T140 Front Brake Hose US or UK Bars - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear Motorcycle.com
Old 11-14-2012, 06:30 AM   #1 (permalink)
Main Motorcycle: 77 Bonneville
I am starting to put my 77 Bonneville together and was planning on replacing all brake hoses. Just not sure which front brake hose I should buy, I am using handlebars with about three inch rise, would anyone have any advice if the hose for the UK bars would be suitable?, or would I need the longer US bars hose?
Thanks,
Bob
BC1976 is online now   Reply With Quote
Old 11-14-2012, 07:56 AM   #2 (permalink)
Moderator
Main Motorcycle: T120V
Caulky's Avatar
Other Motorcycle: 1960 Tiger Cub
Thanks,
Bob
Measure the distance from the master cylinder to the yoke connections.
The short hose for UK bars is 5 3/4 long.
I suspect you`ll need the longer 60-7174 US bar type.
Caulky is online now   Reply With Quote
Old 11-15-2012, 04:48 AM   #3 (permalink)
Thanks Caulky, now that I know the length of the hose I can check what I need. Looks like the US bars hose will be needed. I was hoping to avoid having the longer hose.
Bob
Old 11-15-2012, 06:25 AM   #4 (permalink)
Main Motorcycle: T140 E
they are easy to make, or have yoour local bike shop make you one.
I'd suggest bending a bit of coat hanger wire or welding rod so you have the end to end length..
DAVE M is offline   Reply With Quote
79 front brake hose Snakepit Classic, Vintage & Veteran 0 05-02-2011 06:18 PM
front brake hose joeyantalas Speed Triple Forum 16 02-07-2010 04:07 PM
Legend TT front brake hose polex Hinckley Classic Triples 1 05-03-2008 01:05 AM
front brake hose routing 05Truxter Club Cafe' 2 04-10-2007 07:17 PM
New (used) Bike, Front brake hose length? xactoman Speed Triple Forum 3 10-12-2006 04:46 AM
