Clear the pilot jets first.Take out the air screws and see how far you can push a small wire,no bigger than 0.016" diameter,into the carb body.It should go in at least 1-1/2",if the jet isn't blocked. A 0.026" wire or number 78 drill or 0.4 mm drill should go in that far.
Then check the 2 idle discharge holes near the front lower edge of each slide.If you blow WD-40 from the idle air channel at the side of the carb mouth (take off the air filter to see it),it should come out those 2 holes when the air screw is open about 1-1/2 turns from bottomed.
If all that is clear and it still doesn't idle well with the mixture screws approx 1-1/2 turns from bottomed,look in the float bowls next.The surface may not be flat enough to seal at the gasket,so it sucks air and less idle fuel.The float level/fuel height in the bowl could also be wrong,especially if you have brass float needles.
