is original contact breaker assembly available? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-05-2012, 01:09 AM   #1 (permalink)
Main Motorcycle: my 66' Triumph 650
Other Motorcycle: 2007 Harley softail
wondering if anyone still sells the original points assembly complete? my 66' 650 parts manual calls out for "Contact breaker type 4CA"
thanks, Rick
razman is offline   Reply With Quote
Old 11-05-2012, 04:37 AM   #2 (permalink)
Main Motorcycle: T140 E
if you mean original, as in a copy, then yes.
DAVE M is offline   Reply With Quote
Old 11-05-2012, 07:53 AM   #3 (permalink)
Main Motorcycle: all
Other Motorcycle: 6
Extra Motorcycle: 1952 trike
where?
charlieteabag is offline   Reply With Quote
Old 11-05-2012, 08:00 AM   #4 (permalink)
http://www.thunderbirdspares.com/ind...unction=SEARCH
https://trisupply.co.uk/index.php?me...dbd56f4e36ef5b
Old 11-05-2012, 12:29 PM   #5 (permalink)
Other Motorcycle: 6
thanks . british cycle are out of 54425160 Thanks Charlie
Old 11-05-2012, 12:33 PM   #6 (permalink)
Other Motorcycle: 6
thanks, Rick
I Have good used ones . Points and condenser on plate Charlie 585 589 0763 email akey42000@yahoo.com
Old 11-05-2012, 12:35 PM   #7 (permalink)
htown16's Avatar
Unless you are doing a by the book the restoration, I believe the 6ca might be a better option. The point sets are easier to adjust because of independent mounting, but you would have to mount condensers somewhere. Given the amount of bikes converted to EI, I would think you could find a used set somewhere. You would also need the auto advance unit.
Htown16, Houston, Texas
1978 T140E Bonneville, 2004 XL 1200R Sportster, 1972 Commando,
1974 Commando, 1970 BSA Thunderbolt
Everything will be alright in the end.
If its not alright, its not the end.
htown16 is online now   Reply With Quote
Old 11-05-2012, 01:56 PM   #8 (permalink)
Main Motorcycle: 1979 Bonneville T140E
Check out Baxter Cycles in Iowa. (www.baxtercycle.com) They've given me pretty good service. When I call in an order, I usually have it in 2-3 days.
ramengr is offline   Reply With Quote
Old 11-05-2012, 06:28 PM   #9 (permalink)
Moderator
Main Motorcycle: Rickman T120
Other Motorcycle: T160,TR6
The 4CA breaker plate is rubbish,and should be replaced by the 6CA or 8CA breaker plate.The later plates have independent timing adjustment,and condensors mounted near the coils instead of under the points cover and integral with the points.
The only way to get accurate timing with 4CA is by making one points gap bigger or smaller than spec.
6CA,8CA use different points,but are basically the same.The points changed about '73.
It's a very good ides to also use the 6CA AAU,which has a cam with 160 degrees dwell.The different cam can prevent melted pistons;even if the timing is right.
If the cam looks as though the points close for almost as many degrees as they open,you have the correct better AAU.
Mr.Pete is online now   Reply With Quote
Removing contact breaker unit, 73 Tiger stucknarut Classic, Vintage & Veteran 4 10-01-2012 07:35 AM
Contact breaker lock bolt triumphjoe Classic, Vintage & Veteran 1 11-30-2010 11:47 PM
contact breaker removal......... 1966 Trophy Classic, Vintage & Veteran 2 11-10-2009 10:56 AM
contact breaker removal 1759AG Classic, Vintage & Veteran 2 03-13-2008 04:41 PM
Contact Breaker Adjustment retrobiker Classic, Vintage & Veteran 3 11-05-2007 03:30 AM
