Restoration project T100R - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 13 (permalink) Old 11-06-2012, 04:37 PM Thread Starter
Main Motorcycle: Triumph T100 - 2K9
khan973's Avatar
Other Motorcycle: Triumph T100 R
Extra Motorcycle: YamaXV535
My only concern was to be able to find the right parts for the right engine. If it's not the right engine or if I can't figure it out, it's going to be a problem, I dont want to buy pistons that wont fit.
Creative person with technical abilities providing awesomness for the masses.
khan973 is offline
post #12 of 13 (permalink) Old 11-06-2012, 06:28 PM
Main Motorcycle: Triumph TR7
Other Motorcycle: T140
Extra Motorcycle: Most of another T140
If you could post some photos of the engine on here, I'm sure you'd get a positive identification of the model & year, close enough for you to get the right parts book anyway. I'm not very familiar with the 500s but I am guessing that Triumph didn't make all that many changes. If yours is the 'proper' timing side bearing, points on side etc (which it must be to seem at all right in a late bike), parts like pistons, bearings and other major components will almost certainly be the same for a spread of quite a few years.
JohnA is offline
post #13 of 13 (permalink) Old 11-06-2012, 10:37 PM
Main Motorcycle: z1000 mk11
Other Motorcycle: 73 T100R
Extra Motorcycle: 2x bsa b31,79 z1000 mk11
Thing to look for is a bump at the lower rear of timing cover indicating its has an end fed crank and not the earlier bushed type main bearing.change occured at similar time to changes to pistons and head design in late 60's though all will be revealed once you break her down and u best put off buying internal parts till you van see what u got.a photo or two will be easy way to suss out id
daturat100r is offline
Help with first Restoration Project jakes10mm Member's Restoration & Rebuild Projects 6 09-03-2009 01:45 PM
Member's Restoration / Project section GrandPaulZ Classic, Vintage & Veteran 0 08-15-2009 12:41 PM
[Restoration Project] 97 Sprint ST -- New to me VooDooPope T3 Sport / Touring Forum 16 02-25-2009 11:54 AM
my restoration project dumbremindr Air Cooled Twins Talk 1 05-11-2008 06:55 PM
2001 Restoration Project Skyblue62 Air Cooled Twins Technical Talk 6 09-29-2007 09:54 PM
