71 T120 Possible Frame Bodge? - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!
Old 11-02-2012, 09:17 PM   #1 (permalink)
Main Motorcycle: 1971 Triumph Bonneville
leylandauto's Avatar
Other Motorcycle: 67 MGB
Is this angle correct or did a previous owner "Modify" it? Not the most elegant welding job I have seen (and can anyone guess the fender color?)
leylandauto is offline   Reply With Quote
Old 11-03-2012, 01:21 AM   #2 (permalink)
Moderator
Main Motorcycle: Rickman T120
Other Motorcycle: T160,TR6
There shouldn't be a weld behind the shocker mounts.The tube would originally be one continuous loop.
The cross-brace/mudguard mount s a welded-in extra modification.The original mudguard mount was made from flat steel and bolted to the shocker bolts.
Mr.Pete is offline   Reply With Quote
Old 11-03-2012, 06:44 AM   #3 (permalink)
Main Motorcycle: 1970 Bonneville
The fender paint appears similar to a 1970 Bonnie.
henryanthony is offline   Reply With Quote
Old 11-03-2012, 06:50 AM   #4 (permalink)
Main Motorcycle: 72 Bonneville
Extra Motorcycle: 05 Harley Superglide
I have a similar issue on a 72 Bonnie, I suspect someone was bobbing it and changed their mind. The rear loop on mine also looks like a kid bent it, not a very smooth curve. I have been wondering what to do about it.
cwood is offline   Reply With Quote
Old 11-03-2012, 08:36 AM   #5 (permalink)
Main Motorcycle: Triumph T140 & TR7
Other Motorcycle: Guzzi T3
Extra Motorcycle: Another Guzzi T3
Crappy welding but the angle looks about right. I guess as long as that weld is strong enough (only takes weight of the loop plus part weight of mudguard), and if it isn't seen when the seat's down, should be ok.
JohnA is online now   Reply With Quote
Old 11-03-2012, 09:15 AM   #6 (permalink)
Thanks for the input. That makes sense it was cut and put back on. I just did not know why. That might explain why the distances between the hinges are 'just' a bit off. The welding is ugly but looks solid. The bike came with another rear hoop that had been cut from some other bike. If that is a normal enough angle then fine.
Old 11-03-2012, 09:18 AM   #7 (permalink)
The metal 'strap' running from one side of the hoop to the to the other that has one hole for a bolt is bent inward (concave). If this is supposed to be flat then that might explain why the two rear grab rail bolt mounts do not quite line up with the holes in the fender. This can be fixed with a big hammer I suppose.
Old 11-03-2012, 09:21 AM   #8 (permalink)
Duh OK, reading the posts fully first would help;
""The cross-brace/mudguard mount s a welded-in extra modification.The original mudguard mount was made from flat steel and bolted to the shocker bolts.""
Thanks Pete. I would then think that means I can cut that brace out and remount as needed. I thought the angle on that brace looked funny.
Old 11-03-2012, 09:33 AM   #9 (permalink)
Main Motorcycle: T140E
The cross brace is pushing your fender down. The fender is supposed to sit withing the frame loop not below it. There is an indentation on the seat pan to accomodate the fender. With that said, everything looks off. The grab bar is angled down and it shouldn't be. The fender is too low. Cut that extra brace off and you will see things start to look right. BTW the angle of the rear loop looks about right.
Scott
Rookster is offline   Reply With Quote
Old 11-03-2012, 12:28 PM   #10 (permalink)
Thanks Rookster. The angle of the cross brace might seem to be off because it is only 'softly' mounted. I will take care of the cross brace soon.
1972 T120 frame question jpj441 Classic, Vintage & Veteran 6 04-07-2012 11:43 AM
A very poor bodge! matt123 T3 Sport / Touring Forum 10 08-01-2010 06:59 AM
71 Frame butchery T120 david_in_ky Classic, Vintage & Veteran 1 09-21-2009 06:30 AM
1959 T120 Frame blue-triumph Classic, Vintage & Veteran 3 08-29-2009 03:14 PM
