Removing ts triangle badge? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-02-2012, 07:44 PM   #1 (permalink)
Main Motorcycle: '74 T140V Chop
Does anyone know how to remove these little rivets without drilling? Do they have to be drilled out?
I want to get the casing powder coated and I would like to fit a new plate (which I have) with new rivets.
Can they just be twisted out? I can't seem to get any pliers on them...
loxx101 is online now   Reply With Quote
Old 11-02-2012, 08:00 PM   #2 (permalink)
Main Motorcycle: 1971 Triumph Bonneville
leylandauto's Avatar
Other Motorcycle: 67 MGB
I have removed slightly larger twist rivets before but not these yet. Maybe if you cut off the rounded edges on two side either with careful hacksaw or small rotary cutoff wheels so you can get some precise edged pliers on them?
leylandauto is offline   Reply With Quote
Old 11-02-2012, 08:19 PM   #3 (permalink)
Main Motorcycle: 1978 Bonneville T140V
Morris the Cat's Avatar
Just peel away the corner of the (soft)aluminum plate with a small screwdriver (put some tape under the edge so as not to scratch)
This will give enough of the screw-nail showing to prise out with a small dike or whatever you have similar.
Safest way but you will ruin the patent plate.
dike = diagonal cutter
or equal
twist it out with a bit of pull- no problem.
Patent plates and screw nails are cheap.
Morris of Main Street
Morris the Cat is online now   Reply With Quote
Old 11-02-2012, 08:27 PM   #4 (permalink)
Nice one Morris, cheers!
I did it that way but snapped two of the rivets out. I hardly even touched them, they were really brittle. Damn. Going to have to drill now. I'll have to stick them in the mill I reckon...
I assume you have to drill anyway for the new oversized ones?
Old 11-02-2012, 08:41 PM   #5 (permalink)
Main Motorcycle: T100R Daytona special
Other Motorcycle: Ducati 748
Extra Motorcycle: Cagiva Mito
You won't drill the rivets they are too hard.
Just drill new holes slightly to the side or above the old ones
Essy to remove the old ones is to peel the old plate completely off with a screwdriver and then grip under the rivet heads with a pair of small sharpened side cutters or pliers and simply twist them out.
Old Cafe Racer is offline   Reply With Quote
Old 11-02-2012, 09:14 PM   #6 (permalink)
Okay, well I have filed the stubs flat so now you can't see where the old plate was. I'll drill new holes just below so all 3 holes are covered with the new plate.
Cheers
Old 11-03-2012, 02:57 PM   #7 (permalink)
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1999 Yamaha Virago 1100
I was told by a Triumph "guru", many years back, when I changed my patent plate, that the old rivets can be carefully driven in until they bottom and that the new ones can be ground down a bit, then tapped in over the old ones. I didn't have to do it, fortunately, but it might be worth a try. They should tap in fairly easily. The "guru" is still doing the classic Triumph scene and is very well respected.
Just the $.02 worth of the "village idiot": Jim
Jim Ballard
jimballard is offline   Reply With Quote
Old 11-03-2012, 04:13 PM   #8 (permalink)
Oh no! Well, I took all the engine parts in today for powder coating so I already filed them flat. Couldn't see where they were after I had done that so I'm going to have to re-drill.
Worth noting for future builds though!
Old 11-04-2012, 04:36 PM   #9 (permalink)
Best that you find the old rivets...............you just might hit one with the drill and mar the cover. Look a bit harder and see if you can find them.
The "village idiot" has years and years of such misadventures under his belt: Jim
Jim Ballard
Old 11-04-2012, 06:02 PM   #10 (permalink)
Main Motorcycle: 1973 T140v
Take it from me..you can't drill the rivets. Like the guy said..they're too hard. I really buggered mine up. I finally got the rivet out, but then had to fill the crater with alumalloy. It worked out fine but what a pain. Be gentle with the dikes..Two rivets came out fine, but the third, I guess I basically cut off
treener is offline   Reply With Quote
Triangle engine plate? loxx101 Twins Talk 15 07-16-2012 07:12 AM
where to get vintage Triumph triangle sticker badge smcquilling Twins Technical Talk 3 06-29-2010 10:19 AM
removing tank badge on Scrambler jamboa2003 Twins Technical Talk 9 04-01-2009 07:59 PM
Triangle Triumph badge jimmy bush Classic, Vintage & Veteran 13 11-18-2008 11:39 PM
