Removing ts triangle badge? - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-04-2012, 06:34 PM   #11 (permalink)
Main Motorcycle: '74 T140V Chop
Well it was the top two that snapped off. The bottom one I got out so there is a tiny hole. I'll just put the new plate on about 1mm below the original holes, located using the bottom one.
Can't wait to see it all powder coated!
loxx101 is online now   Reply With Quote
Old 11-05-2012, 03:45 AM   #12 (permalink)
Main Motorcycle: 1979 T140D Special
Other Motorcycle: 1978 T140E
Just get some fine wire cutters, bite into the end of the rivets and they unscrew very easily.
Cybersausage is offline   Reply With Quote
Old 11-05-2012, 10:12 AM   #13 (permalink)
Main Motorcycle: 1971 T100C
Other Motorcycle: 2011 Triumph 1700 Storm
Small needle nose vise grips but before you do anything, grind the tip flat. Just dress the very end with your grinder and it will be flat enough to get a good grip.
Worked for me
toxic is offline   Reply With Quote
Old 12-13-2012, 02:24 AM   #14 (permalink)
Main Motorcycle: 1965 Triumph Bonneville
Once you get these rivets or screw nails out, what do you replace them with? Where can you get new ones and what are they called?
siglass is online now   Reply With Quote
Old 12-13-2012, 03:49 AM   #15 (permalink)
Main Motorcycle: T100R Daytona special
Other Motorcycle: Ducati 748
Extra Motorcycle: Cagiva Mito
The rivets come with the new plates, I got mine from B.J.Bikes & Bits in Brisbane.
davy
Old Cafe Racer is offline   Reply With Quote
Old 12-14-2012, 10:20 AM   #16 (permalink)
And if the old holes are OK, you just tap them in?
Old 12-14-2012, 01:11 PM   #17 (permalink)
I always try prying up the plate, just to one side of the rivets, sometimes they'll twist themselves right out. If not, the plate tears away, then you give 'em a go with precision nosed pliers.
Check the backside of the timing cover to see where you have the most "meat" to play with for drilling slightly offset holes.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
GrandPaulZ is online now   Reply With Quote
Old 12-14-2012, 06:11 PM   #18 (permalink)
Main Motorcycle: The one I'm riding
FASTLIKEJUDY's Avatar
Other Motorcycle: Norton
Extra Motorcycle: TRIUMPH 5TA
I broke one of the rivets. I measured the depth of one of the remaining holes and determined that I could drive the broken rivet in to the bottom of the hole and have enough remaining depth for the new rivet. Sure enough it worked. It was easier than drilling three new holes and if it failed for some reason I could still drill the new holes.
My $0.02
Good Luck
Team FASTLIKEJUDY
FASTLIKEJUDY is offline   Reply With Quote
Old 12-15-2012, 10:47 AM   #19 (permalink)
Very clever. I really like that idea, although out of several dozen tap screws removed, I've only had a few heads come off, and never have one patially broken off, so haven't yet had an opportunity to employ such a suggestion.
GrandPaulZ
Born Again Bikes
My Photo album
Old 12-15-2012, 04:17 PM   #20 (permalink)
Main Motorcycle: 1968 Triumph T100c
Ultrarepo's Avatar
Other Motorcycle: Lambretta S2 TS1 225
Extra Motorcycle: Lambretta SX150
My $0.02
Good Luck
Team FASTLIKEJUDY
This worked a treat for me this afternoon. 2 rivets came out fine, third one snapped. I found an old micro screwdriver small enough to go down the hole, whacked the stub of the rivet a few times and sure enough, down it went. Shiny new badge now installed.
Thanks FLJ for this tip
Ultrarepo is offline   Reply With Quote
Triangle engine plate? loxx101 Twins Talk 15 07-16-2012 07:12 AM
where to get vintage Triumph triangle sticker badge smcquilling Twins Technical Talk 3 06-29-2010 10:19 AM
removing tank badge on Scrambler jamboa2003 Twins Technical Talk 9 04-01-2009 07:59 PM
Triangle Triumph badge jimmy bush Classic, Vintage & Veteran 13 11-18-2008 11:39 PM
