Pre unit twin primary measurement Help - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGear
Old 11-03-2012, 04:17 PM   #11 (permalink)
Main Motorcycle: Triton
Other Motorcycle: Sportster 1200s
The dome nut in the centre of the chaincase is the screwed rod through hole B to the engine plate on the other side with spacers in the gaps.
TritonTommo is offline   Reply With Quote
Old 11-03-2012, 05:49 PM   #12 (permalink)
Main Motorcycle: Too many to list
Other Motorcycle: 2002 BMW K 1200RS
Extra Motorcycle: 1982 Katana 1100
OOO Very pretty.
Is that a commado front end?
Is that remote filter cooler lines coming from the timing cover?
I see you're not a fan of the swept back either.
johnod is offline   Reply With Quote
Old 11-03-2012, 06:02 PM   #13 (permalink)
The front end is a Yamaha xs650,I've got the original Roadholder front end in the garage but they need renovating.The remote oil filter kit is a Rowbotham conversion,and the pipes are TT's.
Old 11-03-2012, 07:40 PM   #14 (permalink)
Man that looks good, always liked the looks of the older chaincase, over the newer rounder style.
I have a KR converted timing cover in my box of bits too, if i recall is it a commado or trident filter you run with it?
What oil cooler you running?
Old 11-03-2012, 07:48 PM   #15 (permalink)
Thanks.....what parts have you got?
My tank is fibre glass and had to seal it due to the new fuel.
Old 11-04-2012, 07:32 PM   #16 (permalink)
I've got a 66 atlas frame, 59 bonnie engine Sun rebuilt, wheels laced to a 2ls commando front brake ,and the atlas rear hub. Roadholders, couple of slickshifts, and new alloy tanks from I can't remember the name ,but someone on that side of the pond, not the tank shop, Bakers maybe?? Think they were in Wales. Anyway short circuit Lyta style with the indents, and a central oil tank. They are beautiful.
Misc little things, dynamo adjusters for trans etc.
Lots of things but more needed i'm sure.
Old 11-05-2012, 03:06 PM   #17 (permalink)
The oil cooler is a Lockhart,got it in the 80's
Sounds like you've got the makings of a nice bike there,hope to see a pic in the near future.
Pre unit primary Case screws kerryhubbard Classic, Vintage & Veteran 16 09-18-2012 05:22 PM
Primary Chain-case noise (unit engine) - rotor hub T100SS Vintage Technical Tips & Tricks 2 09-14-2012 07:06 AM
Pre-unit primary case and clutch Splittie65 Classic, Vintage & Veteran 11 08-25-2011 04:52 PM
pre-unit primary lubrication josh Classic, Vintage & Veteran 8 06-14-2011 01:29 AM
Pre Unit Primary Chain Inner Case Pattern / Bower Powerbox without Battery jasonlewis100 Classic, Vintage & Veteran 0 10-08-2010 10:43 AM
