Old 01-09-2006   #1 (permalink)
Mad
My rear brake keeps getting tighter and tighter without any adjustment made by me. Is this a common problem? I keep backing off the adjustment before I ride and when I get home the rear brake is so tight that I can barely push the bike while in neutral. I'm afraid one day the rear wheel will lock up while I'm riding the bike.
I guess I shold just take it apart and have a look.
thanks, Mad`
Mad is offline   Reply With Quote
Old 01-09-2006   #2 (permalink)
Favorite Bike: 2002 Triumph Trophy
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1984 Yamaha Virago 700
Definitely take it apart and take a look at it. Just for the sake of argument, do you ride with your foot resting on the brake pedal; is everything moving freely? Also, check the pivots for the pedal and the brake arm; the rear arm has a grease fitting on it and it may be sticking a bit if it hasn't been greased in some time. Don't forget the return spring either, it may be broken. It's a very simple brake, you should have no problem finding the culprit.
Hope this helps; Jim
Jim Ballard
jimballard is offline   Reply With Quote
Old 01-09-2006   #3 (permalink)
Favorite Bike: 01 Sprint ST Turbo
tommyturbo2's Avatar
Other Motorcycle: 01 Bonnie Golden Jubilee
Extra Motorcycle: Suzuki DR400E dirt bike
Mad: Sometimes when a bike is restored the restorer fails to arc the brake shoes in to the radius of the drum after the new brake shoes are installed. This results in the brake shoes dragging which eventually expands and overheats them. I've restored several old Triumphs, and when I received the new shoes, they all have required arcing. Theres also a possibility that one of the shoes may have broken off a chunk and is causing the drag. Either way you have to pull the rear wheel, separate the brake drum and find out what the derangement is. Call me if you have any questions, or email. tommyturbo2
TTG..Three Triumph Garage
tommyturbo2 is offline   Reply With Quote
Old 01-11-2006   #4 (permalink)
Make sure your wheel nuts are tight...
but tighteening brake indicates something is badly amiss. sort it out.. is one of teh few things i would worry about on such a bike. Any chance the operating rod is getting bent ??
A wise man learns from his mistakes..
A genius learns from other peoples mistakes.
panda is offline   Reply With Quote
1970 Tiger parts ?? Jedhook28 Classic, Vintage & Veteran 3 02-04-2008 11:07 PM
1970 Tiger Mad Classic, Vintage & Veteran 5 09-16-2005 01:19 PM
Tiger 955i Probs with rear brake ? Tiger Workshop 7 06-05-2005 03:17 PM
Tiger 955i Probs with rear brake ? Tiger Workshop 2 05-25-2005 04:29 AM
'95 Tiger Rear Brake Rotor Needed (and possibly Sprocket Carrier, Too.) roadweazel Tiger Chat 1 03-17-2005 05:40 PM
