Need help ASAP to take clutch out - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.com
Old 11-03-2012, 04:42 AM   #11 (permalink)
Main Motorcycle: Too dirty to tell
Glad you got it!
Dickie Doyle is offline   Reply With Quote
Old 11-03-2012, 06:20 AM   #12 (permalink)
Main Motorcycle: 73 TR7RV Tiger W/2 carb's
mtnbkr01201's Avatar
Other Motorcycle: Feet............or crawl
Extra Motorcycle: Mtn Bike - GT Zaskar Team
Originally Posted by frogonwheels View Post
Thanks guys but that didn't work. I guess that stupid washer has wedged itself into the bolt's threads, and it will keep the clutch basket from coming out. I tried again to drill a hole in the washer, but after wearing three new bits and barely making a dent, I gave up.
Any suggestions ?
I had the same problem for a different reason - Locktite, took three days to get it loose enough to come out, drilling the washer was the only way I could get mine out.
I had to start with a drill bit that cuts ceramic / glass just to get a hole started, then went to COBALT drill bits, that did the trick, was then able to get a small bolt into the drilled hole and pull it straight out.
Bill G.
An Irishman on a Limey
mtnbkr01201 is offline   Reply With Quote
Need answer ASAP! Thanks... ryno9355 Twins Talk 6 01-23-2012 03:03 PM
NEEDED, ASAP: carbs for S3 orangem2 T3 Sport / Touring Forum 14 08-24-2008 11:28 AM
Clutch Help ASAP BorgCymru Twins Technical Talk 8 09-08-2007 04:44 PM
need help asap! chad104 Triumph SuperSports 6 09-02-2006 07:28 PM
Need Help..ASAP boxsky Sprint Forum 4 04-13-2004 10:25 PM
