| Classic, Vintage & Veteran For Coventry and Meriden Models. Anything pre-Hinckley goes. |
10-22-2012, 08:19 PM
SuperStock Main Motorcycle: 76' Bonneville T140
Posts: 213 Other Motorcycle: 76' Montesa Cota 348 Extra Motorcycle: 76' Kawasaki KT250
RK-M standard 530 chain OK ?
Hello,
Have you used the RK-M standard 530 chain on your Bonneville ?
I got one at a great price, but on their website, it is rated for modern 400cc bikes. It has a rating of 6500 lbs. It looks just as good as the DID I removed. What do you say ?
Thanks.
Terry
10-22-2012, 08:38 PM
Formula Extreme Main Motorcycle: 1978 Bonneville T140V
RKM series, which are from Malaysia, and made for dirt-bikes.
How many links do you have?
The chart shows 106 or 108 links, a standard '76 T140 uses 107 links.
How fat is the chain compared to the narrow original one?
Your new chain is about 24$, my Renold chain was 96$.
My Chinese chain is used only as a temporary one to hook over the rear sprocket when removing the good chain.
Chains are relatively easy to replace- but not so the rear sprocket nor the drive sprocket.
Most aftermarket kits for modern chains include thinner sprocket sets to match o-ring type chains for the old Triumphs and are a considerable expense.
Just some thoughts.
Morris of Main Street
10-23-2012, 02:03 PM
Pole Position Main Motorcycle: The one between my legs
Posts: 3,784 Other Motorcycle: '76 Triumph T140V Extra Motorcycle: Yes
I have one of those chains on a 305 Honda Scrambler that I flog pretty hard in the Motogiro twice a year. It's been holding up fine. I did some research on the web and the chain got great reviews as a good value for the money. So far, I'm happy with mine.
These are not superbikes. I would not go nuts on a chain. You can buy 4 of these for the price of an uber-chain. That means you can reset your chain to zero stretch 4 times.
regards,
Rob
10-23-2012, 03:45 PM
The 'uber-chain' has 107 links to fit the application, and as being an 'odd' number of links, incorporates a 'cranked' link.
Unless this is fitted to your Chinese-Cheapo, it will not fit.
This only applies to a Triumph with a rear disk brake.
Earlier Triumph will take a 106 link chain and the chain mentioned may indeed work.
Just watch out for interference to the crankcase as mentioned earlier.
H*nda and Triumph= two different animals!
Mine is!
10-23-2012, 06:01 PM
Morris, not to argue, but a '76 T140V does not use 107 links. It uses 106.
And I have to say that I've never seen a bike that uses a chain with an old number of pitches or links.
regards,
Rob
10-23-2012, 06:27 PM
10-23-2012, 08:27 PM
That's interesting, Morris. Go check the General Data section of your OEM service manual. You'll see they list the chain as 106 links.
I wonder which one is the typo. I checked other manuals and the same two numbers exist in each of the respective manuals. My '76 has a DID chain on it so probably a replacement. I did not count the links, but it is an even number with a normal masterlink.
I did search several chain sites and looked at all the various brands and models. Not a single odd number link chain in the lot. I suspect the 107 links in the parts book is a typo.
Your chain is the first time I've seen an offset link like that on a bike. I've only seen them on farm machinery and similar. Are you sure it's a Triumph and not a Massey-Fergusson?
Guess it's of little consequence. But glad we found this discrepency. If I remember, I'll put my '76 on the centerstand and count the links to confirm the 106 number. Might find it is 108.
Anyone else ever see an offset link on a bike chain before?
regards,
Rob
10-23-2012, 09:17 PM
Sorry Rob,
The OEM service manual was correct before the introduction of the rear disc brake for '76-'77.
After that, the parts manual, as indicated, shows the correct info.
The original front disc was slightly ammended to standardise with the newly introduced rear disc.
In order to fit the rear disc over the swingarm assembly, and match up to the new caliper, and to fit the tire under the fender, an ammendement to 107 links was required.
Don't take my word for it- go try to fit a 106 link chain.
That's why we need the 'Uber' chain to match the Factory supplied chain.
To my understanding- Renold chain is no longer available- not sure why.
With both new sprockets and chain, am glad to have the 'uber' variety, ie; original equipment on mine.
If your'e happy with yours- GFY!
10-23-2012, 10:08 PM
Hi guys,
Thanks to both of you for " reassuring " me I was not crazy in over thinking the rear chain on a T140. You both are showing each side of what I have found out so far : most say it takes 107 links for the T140 and yet, the factory 76' shop manual states it takes 106 links.
My 76' Bonneville had when I bought it a DID chain with 106 links. The sprockets are the stock 20 tooth in the front & 47 tooth in the rear.
That chain was half-way worn out, but fitted perfectly with the axle mid-way in the swingarm slot.
I ordered new sprockets and through a friend, I got a RK-M chain with 106 links. This chain is NOT Chinese. It is made in Malaysia under the ownership of RK Japan with the same steel from Japan. All Japanese motorcycle manufacturers have plants in Malaysia ( Kawasaki 650 KLR has been built there for 28 years for example ) and it made sense for RK Japan to open a factory there to provide OE for all these customers with cheap labor cost )
The RK-M ( M for Malaysia ) is exactly the same size and fit as the old DID I took out. And it is rated for 6800 lbs, which is in reality pretty good for a cheap chain in cost.
Yet, because it is rated for 400cc, I got a bit worried it would be under-specked for the torque of our Bonneville Triumphs.
I called Raber's in San Jose CA, and was told ALL Bonneville should take a 107 links chain. Was told they sold 33 such chains this year for T140 specs.
So, here we are : until I get my new sprockets and do install the chain, I am still not sure what number of links will be needed.
Funny stuff about an odd number of links, I was like Snakeoil as it didn't make sense. Thanks to Morris the cat and his photo of the extra odd weird link, I would have never believed it.
All Raber's chain are even numbered ( 106, 108 ) but they have one Diamond chain for the T140 with....107 links ! That is the one I ordered. When I get it, I will install it and let you know how it all worked out.
Terry
10-23-2012, 10:11 PM
what does GFY mean ?
Yes, what dost GFY mean ?
One answer came up to me right of way, but it can't be.
Let me know.
Terry
