Fuel stabiliser? - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comSportbikeTrackGearMotorcycle.com Classifieds!
Old 10-21-2012, 04:04 PM   #1 (permalink)
Main Motorcycle: '79 T140D UK Special
Vince C's Avatar
Other Motorcycle: Suzuki Freewind, C90
Fuel stabiliser?
Can anyone recommend a fuel stabiliser to put in the tank over winter (I don't run the bike once the salt's down)? If it also cleans jets etc, so much the better!
Vince C is offline   Reply With Quote
Old 10-21-2012, 04:23 PM   #2 (permalink)
Main Motorcycle: my bonneville
keithf's Avatar
Other Motorcycle: bonneville t100
Extra Motorcycle: thunderbird 1600
http://www.ebay.co.uk/itm/CLASSIC-MO...item3f0e087871
am using this in my 1955 350 ajs
it's had some good repots
keithf is offline   Reply With Quote
Old 10-21-2012, 04:33 PM   #3 (permalink)
Main Motorcycle: T140D
Keith B's Avatar
Other Motorcycle: Aprilia Tuono
I use this Putoline liquid stabiliser.There is enough in the bottle to do all 3 bikes in my garage.
Keith B is offline   Reply With Quote
Old 10-21-2012, 05:14 PM   #4 (permalink)
Main Motorcycle: 1968 T120 UK.
Dr Fene's Avatar
Other Motorcycle: 2 Cubs.
Extra Motorcycle: BMW 650 Dakar.
I use
StartronEnzyme StartronEnzyme
when I leave the bike for long periods. Recommended by GABMA
________________
Dr Fene is offline   Reply With Quote
Old 10-21-2012, 09:20 PM   #5 (permalink)
Main Motorcycle: 1971 Triumph Bonneville
leylandauto's Avatar
Other Motorcycle: 67 MGB
Stabil Marine Formula (dark colored). Never left me down on any of the MGs or outdoor power equipment.
leylandauto is offline   Reply With Quote
Old 10-22-2012, 05:18 AM   #6 (permalink)
Main Motorcycle: T140 E
not what you asked, but I rotate the fuel in my bikes to the car and refill half way through winter.
DAVE M is offline   Reply With Quote
Old 10-22-2012, 05:54 AM   #7 (permalink)
Main Motorcycle: 1979 T140D Special
Other Motorcycle: 1978 T140E
I use a similar product to this.
Cybersausage is offline   Reply With Quote
Old 10-22-2012, 02:01 PM   #8 (permalink)
Main Motorcycle: The one between my legs
Snakeoil's Avatar
Other Motorcycle: '76 Triumph T140V
Extra Motorcycle: Yes
I have used several products in both my bikes and my boat. I've owned my boat since it was new in 1993 and before E-10 showed up.
Stabil - regular gasoline formula
Valvetec - recommended by local marina owner and he has it in all his marine gas he sells
Lucas Products stabilizer - for ethanol laced gasolines
Stabil for Ethanol Fuel
I've never had a problem with any bikes or my boat using any of these.
For the boat, I've always put the stabilizer in the fuel when I add fuel to the tank because the boat sits a lot.
For the bikes, I add stabilizer when I winterize them.
I also have a Miata that I winterize and used those products in that car as well with no issues to date. Owned that car about 11 or 12 years now.
One point for those who may have older vintage bikes with cork seals in the petcocks. Don't drain your tanks or your seals will dry out and shrink. Those with these bikes probably already know that. I learned the hard way.
regards,
Rob
Snakeoil is offline   Reply With Quote
Old 10-23-2012, 05:44 PM   #9 (permalink)
Main Motorcycle: Shovelhead.
Emanthehorse's Avatar
Other Motorcycle: 2013 T100
Extra Motorcycle: 1971 Triumph TR6R Chop.
And just a quick word to those who like to just fill up the tank and not bother with a stabilizer, opting to just drain and refill in the spring.
These two identical pieces of mild steel tubing were completely submerged in E10 gas for a few weeks. One had stabilizer added. Guess which.
E10 is evil stuff.
Emanthehorse is offline   Reply With Quote
Old 10-23-2012, 08:34 PM   #10 (permalink)
Snakeoil's Avatar
Eman, that's very striking. Was the container open to the air or were they sealed containers?
What is that on the ugly piece, rust or crud?
Since our tanks are bare steel, I would expect them to look the same inside as your ugly sample. But they don't... at least mine don't.
Did you do this experiment yourself or is this info you found on the web?
Thanks,
Rob
URGENT PLEASE: 08-09 Fuel Tank on a 07??? Fuel Pump Assembly Problems/Compatibility Sweatypants Speed Triple Forum 4 10-02-2010 12:09 AM
Quick-Disconnect Fuel Fittings and Rear Hinged Fuel Tank dealsgapdragon Maintenance & Workshop Talk 0 04-05-2009 12:42 PM
Gold Eagle Sta-Bil Petrol Stabiliser Linz RAT - Australia 2 01-10-2009 04:24 PM
Sprint ST Fuel Line Question (fuel tank to/from fuel rail) Sprint Forum 7 01-26-2005 09:23 AM
Fuel Stabiliser in UK Maintenance & Workshop Talk 11 01-19-2005 06:12 PM
