| Classic, Vintage & Veteran For Coventry and Meriden Models. Anything pre-Hinckley goes. |
09-20-2012, 06:03 PM
World SuperBike Main Motorcycle: 1953 Triumph Black bird
Posts: 2,436 Other Motorcycle: 1978 Yamaha DT400
Running on one cylinder.
My 6T is only running on cylinder #2. Cylinder #1 has spark and cool air coming out the exhaust. Does this sound like a valve problem?
Kem
A man cannot be comfortable without his own approval.
Mark Twain
09-21-2012, 01:17 AM
Anyone? I want to ride it and not just look at it.
Kem
Mark Twain
09-21-2012, 01:50 AM
Moderator
Moto Grand Prix Main Motorcycle: Rickman T120
Posts: 2,923 Other Motorcycle: T160,TR6
If cyl 1 has compression,just replace the spark plug.
If it doesn't have compression,check the valve clearances and make sure the valves are moving up and down and not sticking when you turn the engine.
If the valves seem OK and there's still no compresssion,take off the head and look for a hole in the piston.
09-21-2012, 02:39 PM
Thanks MrPete.
Kem
Mark Twain
12-02-2012, 07:19 PM
I'm perplexed because the spark is great, I watched the valves move while the engine was running and it has enough compression to blow my finger off the spark plug hole.
The bike sounds like it's misfiring, so could this be a timing issue?
Kem
Mark Twain
12-02-2012, 07:28 PM
World SuperBike Main Motorcycle: 2012 Bonneville T100
Posts: 2,269 Other Motorcycle: 1970 Triumph Tiger 650 Extra Motorcycle: 1999 Yamaha Virago 1100
I'd change the spark plug........simple fix if it's the problem. You could also check for a holed piston with a small flashlight shined down the plug hole; but it sure sounds like an electrical problem. Also, when the engine's running, it still might generate enough compression to move your finger off the hole, but not enough to fire the cylinder properly.
Just the $.02 worth from the "village idiot": Jim
Jim Ballard
12-02-2012, 11:23 PM
Grand Prix 250 Main Motorcycle: T140V Bonny '77
Posts: 80 Other Motorcycle: T120R '71
Swap the plugs
12-03-2012, 12:31 AM
I have swapped the plugs twice.
Kem
Mark Twain
12-03-2012, 10:44 PM
What plugs are the best replacement for the discontinued Champion L10? It currently has Champion L82C plugs.
Kem
Mark Twain
12-04-2012, 09:19 AM
Site Supporter Formula Extreme Main Motorcycle: 1977 T140V
Posts: 872 Other Motorcycle: 1949 Ariel SQ4 Extra Motorcycle: 1945 WL (Civilian)
Are you using points or EI? Getting a good spark doesn't mean much if it sparks at the wrong time.
