Running on one cylinder. - Page 4 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-08-2012, 04:57 AM   #31 (permalink)
Main Motorcycle: T110 Triton
Triton Thrasher's Avatar
Originally Posted by Kem770 View Post
It has a magneto.
Kem
Then forget the wiring diagram!
Did it ever run right with you?
Check the points gap on both lobes of the ring cam. Page 165-on in this manual.
http://classicbike.biz/Triumph/Repai...umphRepair.pdf. The usual cause of them going onto one cylinder, in service, is an owner neglecting to check and adjust the points, so they stop opening. One side always stops opening first. If it's a bike coming out of storage, or newly refurbished, suspect more serious magneto problems, but if it's firing well on one cylinder but not at all on the other, it may be a simple points or cam issue. Does the other cylinder chime in if you rev up?
Are the HT leads attached to the mag pickups? Are the pickups damp or dirty, inside our outside the magneto? Are both pickup brushes in place?
Triton Thrasher is offline   Reply With Quote
Old 12-08-2012, 05:00 AM   #32 (permalink)
That's on my list for Sunday. I noticed when I tickle the carb I no longer get fuel on my finger.
Kem
Just noticed this. Is there fuel in the tank?
There's usually a gauze on the tap, protruding up into the tank. It gets blocked. There'll be another strainer where the pipe goes into the carburettor.
Old 12-08-2012, 11:45 AM   #33 (permalink)
Main Motorcycle: 1953 Triumph Black bird
Kem770's Avatar
Other Motorcycle: 1978 Yamaha DT400
Yes, there is fuel in the tank.
Yes, it was running fine before it stalled on the side of the road. I can get it started on the first or second kick and it runs okay on the one cylinder.
Kem
A man cannot be comfortable without his own approval.
Mark Twain
Kem770 is offline   Reply With Quote
Old 12-08-2012, 01:48 PM   #34 (permalink)
Main Motorcycle: 1970 Bonneville
Kem
But, is the fuel flowing out of the tank, into and through the carb? You need to check for any blockage in the system.
henryanthony is online now   Reply With Quote
Old 12-08-2012, 04:20 PM   #35 (permalink)
Kem770's Avatar
I'm checking this tomorrow because I'm wondering if the screen is clogged.
Kem
Mark Twain
Old 12-09-2012, 09:11 PM   #36 (permalink)
Kem770's Avatar
Since the wind child today was -4, I didn't troubleshoot the bike today. I hope I can get to it on Tuesday.
Kem
Mark Twain
Old 12-09-2012, 11:14 PM   #37 (permalink)
Kem
Right, winter certainly has a demotivating effect on anything to do with motorcycling whether riding or wrenching.
Old 12-11-2012, 06:02 PM   #38 (permalink)
Kem770's Avatar
I ordered new spark plug wires from Baxter today, so I'll probably have them tomorrow. Yesterday I changed the spark plugs and checked the fuel flow.
Kem
Mark Twain
Old 12-15-2012, 07:19 PM   #39 (permalink)
Kem770's Avatar
Because of Christmas, I haven't had time to work on my bike. My wife seems to think I need to be decorating our home and shopping. I disagree and think I need to be working on my bike. For anyone married I'm sure you know who won out.
I did get the new spark plug wires this week but they are for a Lucas mag not a BTH. Randy Baxter says I can take my old plug wires and new plug wires and move the mag end of the old wires to the new wires.
Has anyone here done this? It seems like it should work.
Also, I pulled one of the old wires off tonight and noticed oil on the ferrite tip, so I stuck my finger in the hole and it came out oily. This can't be right.
I'm done shopping, so I'm in the shed tomorrow.
Kem
Mark Twain
Old 12-16-2012, 03:34 AM   #40 (permalink)
Kem
So it's an old BTH magneto?
What is a "ferrite tip?" Do you mean the carbon HT pickup brush? It should not be oily. Clean both of them in petrol. Clean the slip ring (thing inside the magneto that they rub on), with petrol on a rag. Hold the rag against the slip ring with a stick and spin the engine. Short circuit the kill switch terminal to earth while doing that, to avoid 5000 volts up your arm.
The oil seal at the drive end of the magneto may be leaking and letting engine oil into the magneto. If cleaning the brushes and slip ring helps your problem but not for long, the seal, the bearings and bearing insulators may need attention.
Of course you are supposed to fit new HT leads (wires) into the pickups the same way the old ones are fitted.
There is probably an earth brush somewhere under a screwed cover on the outside of the magneto. It wears and gets dirty too.
running on one cylinder irontriumph Classic, Vintage & Veteran 12 09-02-2011 03:46 PM
running on one cylinder irontriumph Twins Technical Talk 1 08-27-2011 08:37 PM
running on one cylinder reyals140 Classic, Vintage & Veteran 3 01-28-2009 09:51 PM
running on one cylinder bonnecom Twins Technical Talk 23 01-10-2008 05:19 PM
Running on one cylinder... GrayMitchell Classic, Vintage & Veteran 2 09-09-2007 04:44 AM
