Running on one cylinder. - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!SportbikeTrackGear
Old 12-05-2012, 05:17 PM   #21 (permalink)
Other Motorcycle: 1970 Triumph Tiger 650
Extra Motorcycle: 1999 Yamaha Virago 1100
That wiring diagram is for the T110 and T100. I'm trying to remember, but I'm pretty sure that the 6T has the distributor/coil and not the magneto, as shown. Do you have one for the 6T specifically?
Jim Ballard
jimballard is offline   Reply With Quote
Old 12-05-2012, 06:58 PM   #22 (permalink)
Main Motorcycle: 1953 Triumph Black bird
Kem770's Avatar
Other Motorcycle: 1978 Yamaha DT400
This is from the factory manual that came with the bike, but the manual does cover several bikes from 1953.
Do you have the diagram for a '53 6T?
Kem
A man cannot be comfortable without his own approval.
Mark Twain
Kem770 is offline   Reply With Quote
Old 12-05-2012, 08:51 PM   #23 (permalink)
Main Motorcycle: 1979 Bonneville T140E
My T140E had a problem with only firing one one cylinder intermittently this summer. I was going over everying. Compression, plugs, points, condensers, coils. They all checked out.
Then cleaned all of the connections in the ignition system. That did it.
Guess I shoulda done that first. :\
ramengr is offline   Reply With Quote
Old 12-06-2012, 05:50 PM   #24 (permalink)
I'm sorry, Kem, I don't. I was only going from memory and the fact that an old friend had a 6T. They must be available online, or at least from one of the specialists out there.
Wish I could be more of a help: Jim
Jim Ballard
Old 12-06-2012, 08:11 PM   #25 (permalink)
Main Motorcycle: '59 thunderbird
Other Motorcycle: '95 Thunderbird
6T Wiring
Kem
See if this helps.
loctitekid is offline   Reply With Quote
Old 12-06-2012, 08:57 PM   #26 (permalink)
Moderator
Main Motorcycle: Rickman T120
Other Motorcycle: T160,TR6
What would really help is knowing if this bike has distributor or a magneto.
Even if it has a distributor,this is not a wiring problem.If the coil can fire one cylinder,the coil,condensor and wiring are OK.
Do the points open twice for every full rotation of the shaft?There are more things to check if you only tell us whether it has a distributor or magneto.
Mr.Pete is online now   Reply With Quote
Old 12-06-2012, 10:35 PM   #27 (permalink)
Kem770's Avatar
It has a magneto.
Kem
Mark Twain
Old 12-07-2012, 06:02 PM   #28 (permalink)
Main Motorcycle: 74 Bonneville
Have you checked for good fuel flow ? Sounds like maybe there's a carb/gas problem to me.
Bison is offline   Reply With Quote
Old 12-08-2012, 12:32 AM   #29 (permalink)
Kem770's Avatar
That's on my list for Sunday. I noticed when I tickle the carb I no longer get fuel on my finger.
I want to thank everyone for all the helpful information. I'm new to Meridan Triumphs so you, my father-in-law and the user manual are invaluable.
Kem
Mark Twain
Old 12-08-2012, 12:38 AM   #30 (permalink)
Kem770's Avatar
I posted twice.
Kem
Mark Twain
running on one cylinder irontriumph Classic, Vintage & Veteran 12 09-02-2011 03:46 PM
running on one cylinder irontriumph Twins Technical Talk 1 08-27-2011 08:37 PM
running on one cylinder reyals140 Classic, Vintage & Veteran 3 01-28-2009 09:51 PM
running on one cylinder bonnecom Twins Technical Talk 23 01-10-2008 05:19 PM
Running on one cylinder... GrayMitchell Classic, Vintage & Veteran 2 09-09-2007 04:44 AM
