| Classic, Vintage & Veteran For Coventry and Meriden Models. Anything pre-Hinckley goes. |
12-04-2012, 11:38 AM
#11 (permalink)
World SuperBike Main Motorcycle: 1953 Triumph Black bird
Posts: 2,436 Other Motorcycle: 1978 Yamaha DT400
Originally Posted by Ohio-Rider
Are you using points or EI? Getting a good spark doesn't mean much if it sparks at the wrong time.
It has points. I was riding at about 65 mph when it started sputtering and then died. I got it started but it wasn't running very good; Sputtering, no power and it died several times during the last 5 miles home.
Kem
A man cannot be comfortable without his own approval.
Mark Twain
12-04-2012, 12:36 PM
#12 (permalink)
Pole Position Main Motorcycle: T140 E
Posts: 3,500 Other Motorcycle: 56 Plunger Tatty Cub Extra Motorcycle: CZ winter bike
Dodgy coil?
swap the coils and see if the problem moves
12-04-2012, 12:55 PM
#13 (permalink)
SuperSport Main Motorcycle: 1970 Bonneville
Have you checked for proper fuel supply? Might be a poor connection or partially broken wire that is hidden inside the insulation.
12-04-2012, 01:56 PM
#14 (permalink)
Moderator
Moto Grand Prix Main Motorcycle: Rickman T120
Posts: 2,926 Other Motorcycle: T160,TR6
Originally Posted by Kem770
It has points. I was riding at about 65 mph when it started sputtering and then died. - - - - - - - - -
The plot thickens.It sounds like you have a distributor and single coil.Is that the case?
Was the bike running well for a reasonable time,before this dying and sputtering started?
12-04-2012, 04:13 PM
#15 (permalink)
Formula Extreme Main Motorcycle: T110 Triton
Wouldn't hurt to post pics of the ignition system.
If it's distributor and coil, those symptoms could be a battery not getting charge.
12-04-2012, 09:49 PM
#16 (permalink)
Formula Extreme Main Motorcycle: '59 thunderbird
Posts: 703 Other Motorcycle: '95 Thunderbird
My 6T is only running on cylinder #2. Cylinder #1 has spark and cool air coming out the exhaust. Does this sound like a valve problem?
Kem
I'm thinking about an intermittent spark problem. Could be wrong, but easy to eliminate.
Distributor or magneto?
If it's a distributor, check the thin wires to and from the coil and distributor. Pay attention to any connectors - they might have vibrated loose (nuts fall off) or they might have oil on them.
If it's a magneto, try removing the HT pickups and cleaning the carbon brushes. Use a cotton bud or similar to clean the armature where the brushes run.
Hope this helps.
Cheers,
Neil.
12-05-2012, 01:51 AM
#17 (permalink)
SuperStock Main Motorcycle: TRIUMPH T140E
Posts: 224 Other Motorcycle: BSA B44 Victor Extra Motorcycle: Triumph Street Triple
Have you checked the condirion of the points - asre they pitted ? is the gap correct ?.
12-05-2012, 06:15 AM
#18 (permalink)
Site Supporter Formula Extreme Main Motorcycle: 1977 T140V
Posts: 873 Other Motorcycle: 1949 Ariel SQ4 Extra Motorcycle: 1945 WL (Civilian)
The reason I asked about which ignition you’re using is because two years back I had my front cylinder quit on me. The set screw for the front points had come lose and the points closed up killing just that cylinder. Check the simple things first.
12-05-2012, 09:34 AM
#19 (permalink)
Pole Position Main Motorcycle: The one between my legs
Posts: 3,773 Other Motorcycle: '76 Triumph T140V Extra Motorcycle: Yes
What about the condenser? I would think that a failing condenser would give you spark during a test but poor performance when running. If points, coil and plug are good, then condenser might be at fault. Mr. Pete mentioned you have a distributor. Any chance the the post for that cylinder is damaged?
Locktite mentioned this. First, make sure you have continuity to all your termination points, the terminations are good and you have power where you need it. After that it is proper function of the system (timing, advance, points gap, etc.) and proper function of the components (points, condenser, coil plug cap, etc) that determines the proper operation of the system.
Maybe I missed the comment, but I know you said that the compression blows your finger off and someone said that is not necessarily a good test. I agree with that and you need to do a proper compression test. That will prove out the integrity of the engine bits and let you eliminate them from the list of possible causes.
Troubleshooting boils down to isolating and eliminating.
regards,
Rob
12-05-2012, 03:18 PM
#20 (permalink)
Here is the wiring diagram for a 1953 6T. I'm heading to the shed later on to try some of your suggestions.
Kem
Mark Twain
