1969 t100s rear wheel, anchor plate distance piece??? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 4 (permalink) Old 09-10-2012, 04:07 PM Thread Starter
Main Motorcycle: 1969 t100s
Hi all
any help would be most appreciated.
I'm reassembling a 1969 t100s and am having some trouble with the rear wheel. Two questions:
The distance piece that sits between the retaining ring/bearing and the brake anchor plate won't seem to allow for the anchor plate to seat fully. This wasn't the case on disassembly...Any chance that bearing shifted position somehow?? The distance piece now sits against the inner bearing race, and doesn't seem to fully seat against the retaining ring..
What is the proper procedure for reinstalling the wheel, in particular how does one tighten the spindle/axle nuts. Does one TIGHTEN the inner nut against the speedodrive, and its opposite against the brake anchor plate, and then tighten the outer nuts squeezing in the swingwarm towards the wheel, or does one just snug up the inner nuts against the anchor plate and speedo and bring home the outer spindle/axle nuts??
tommyj is offline
post #2 of 4 (permalink) Old 09-10-2012, 04:16 PM Thread Starter
i'm trying to post some pics, but it seems today my difficulties extend beyond the mechanical!
tommyj is offline
post #3 of 4 (permalink) Old 09-10-2012, 04:25 PM Thread Starter
a pic of where the spacer sits, but it abuts against the inner race and doesn't seem to seat fully ???
tommyj is offline
post #4 of 4 (permalink) Old 09-25-2012, 05:34 PM
Main Motorcycle: "72" T100R
I'm right there with you Tommy. How much torque on those inner spindle nuts? I am working on a T100R
Marty
10-91v is offline
1969 T100S Rear Wheel Sprocket Bolt Concern newtriumphowner Classic, Vintage & Veteran 16 09-22-2013 09:34 AM
Try to repair or replace anchor plate? triumpt120rv Classic, Vintage & Veteran 7 08-15-2011 09:09 PM
1969 T100s Terrance The Welcome Center 2 06-09-2011 03:14 AM
Front brake anchor plate paul lavery Classic, Vintage & Veteran 3 08-03-2010 04:00 AM
Need Help - How To Remove Rear Wheel On 1969 T100S newtriumphowner Classic, Vintage & Veteran 5 01-19-2010 08:57 AM
