3TA electronic ignition - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 09-03-2012, 05:34 PM   #1 (permalink)
Main Motorcycle: Tiger 650 '72
Other Motorcycle: "Trivarna"
Hello all,
In the next few weeks I will be starting with the rebuild of 1960 3TA engine with distributor.
I want to fit an electronic ignition. I knew I can either convert it to side ignition and then use a Boyer system or similar or I can also get a system that uses the distributor (with a small modification).
But today I came across the electrex system that replaces the alternator with a combined alternator /electronic system (see link below).
Have any of you got any recommendations/comments about fitting these 3 systems?
Many thanks,
Nielo
http://www.electrexworld.co.uk/cgi-b...2D#aSTK_2d102D
Nielo is offline   Reply With Quote
Old 09-04-2012, 06:48 AM   #2 (permalink)
Main Motorcycle: T140 E
they get good write ups on Tigercubs. ( different system but same company) -I think
DAVE M is offline   Reply With Quote
Old 11-11-2012, 06:29 AM   #3 (permalink)
I finally bought the electrex ignition and will be fitting it in the next few weeks. The parts look nice and well made so hopefully it will work out.
Cheers,
Nielo
Old 11-11-2012, 09:45 AM   #4 (permalink)
Main Motorcycle: bsa bushman
Other Motorcycle: t100 790
Extra Motorcycle: 66 tr6
iv got 3 of them, they are great it does away with so much junk and theres so few wires once its on it realy is fit and forget,personaly i think its better than electronic ignition i went for the ac output one so no battery etc but they also do normal dc set up.you dont even need a good keyway on the crank its self locking.
1963wak is offline   Reply With Quote
Old 11-15-2012, 05:42 AM   #5 (permalink)
Thanks for your reply. Glad to hear that it should work fine.
Do you have a rev counter fitted to the ignition? My engine is from 1960 and doesn't have an option to fit a mechanical rev counter but I have seen digital rev counters that look ok. According to Electrex I can fit any rev counter that takes a CDI input but I ahven't looked into this yet.
Old 11-15-2012, 08:26 AM   #6 (permalink)
you can fit a rev counter but if you do it might be best to go for there dc output system as you will need 12v dc for the tacho,it triggers off the coil wire.
Old 11-15-2012, 01:09 PM   #7 (permalink)
yes I have the dc output system. Do you know of a make/model of rev counter that would work?
Thanks for your help.
Old 11-15-2012, 01:26 PM   #8 (permalink)
smiths do them,they look just like the cable ones,if your not to bothered about the looks there are loads of universal ones on fleebay.as you are running a twin coil a 4 cylinder one will work.
Old 05-04-2013, 02:39 PM   #9 (permalink)
Just in case somebody is interested in the Electrex ignition. It was very easy to fit. I struggled getting all the wires trough the little tube in the crankcase but with hindsight I should have unscrewed the tube, fed the wired though and screwed it back in. I just tried and it fired up first kick! Only problem I have now is that the oil is not returning but that is not electrexworld's fault.
Old 05-04-2013, 09:31 PM   #10 (permalink)
Moderator
Main Motorcycle: Rickman T120
Other Motorcycle: T160,TR6
Drain the crankcase and remove the return line at the oil tank.Blow compressed air up the pickup tube in the crankcase and through the return pump.You might need to turn the engine a little,so the pump is in the right position to let air through.
The little piece of rubbish stopping the pump should blow out the return line.Fit the drain plug back and put 100ml of oil in the crankcase.Start the engine and see if oil comes out the return line.The piece of rubbish might come out too.
If it doesn't work,you can try again or pull the pump apart.
Mr.Pete is offline   Reply With Quote
Electronic Ignition help 1966TR6C Classic, Vintage & Veteran 19 02-14-2011 10:46 AM
Electronic ignition dkreidel Classic, Vintage & Veteran 5 02-11-2009 02:26 PM
electronic ignition? smorick37 Twins Technical Talk 0 07-29-2008 11:03 PM
electronic ignition help. nate440 Maintenance & Workshop Talk 1 09-18-2007 01:00 AM
6v electronic ignition COOPERS Classic, Vintage & Veteran 0 12-20-2004 05:46 PM
