Originally Posted by Cybersausage
Just for info..I was told that these bearings wear out causing excessive play, if your chains are too tight.
That is certainly true sausage.I think the original poster has put this together with a wrong or worn part.As the video shows,he didnt realise there must be no play in the gearbox shaft.
Personally,i have never had a leak in this area in 34 years of T120 playing and i dont use any silicone on the shaft.I suppose if i had a close look there might be a weep.The silicone looks like good workshop practice so i might try it next time around
