Old 12-17-2005   #1 (permalink)
A buddy is rebuilding a 69 Bonneville and has installed new carbs. It starts easy and runs fine but he thinks it idles too fast. He's trying to get it under 1000 RPMs. What's realistic?
Silvergator is offline   Reply With Quote
Old 12-17-2005   #2 (permalink)
Moderator
Favorite Bike: Triumph Bonneville
Other Motorcycle: Britiron
Have the carbs re-sleeved. The old Amals suck wind from around the sloppy slides.
A couple of my old Bonnies will do the "plump-plump, plump-plump, thumpa-thump" type idle at about 800 RPM because they have tight carbs, the others I have set at 1,000 RPM or they will falter and die no matter how much balancing and tweaking.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photos
Old 12-20-2005   #3 (permalink)
vik
Yes, 800 rpm is possible, it all has to do with the flywheel, so you won't be quite in the H-D class but near enough.
Obviously the engine needs to be in good working in order to achieve this and then only still when it is fully warmed up will it be able to turn over at such low idle without stalling.
I forgot to add that it is also related to the state of tune, that is why I suppose that Paul's other Bonnies won't go that low because they probably have "hot" cams and high compression. But even then 1000 rpm for a vertical twin with relatively heavy flywheel seems quite high to me.
Note : For my 1994 Sprint 1000 rpm is the normal idle speed.once it is off the choke
[ This message was edited by: vik on 2005-12-21 05:07 ]
Triumph or Die
vik is offline   Reply With Quote
After reving, rpms dip way below idle JonahP Twins Talk 11 09-24-2006 02:28 PM
hesitation under 2k rpms podman Sprint Forum 15 09-07-2006 08:09 AM
Idle RPMs Silvergator Twins Talk 11 12-19-2005 11:50 AM
Idle RPMs MikeinLA Twins Talk 2 08-14-2005 11:25 PM
RPMs at idle... vdlcinc Sprint Forum 8 05-09-2005 09:27 PM
