possible carb swap - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 07-18-2012, 10:44 PM   #1 (permalink)
Main Motorcycle: custom harley
Other Motorcycle: 71 TR6
Extra Motorcycle: varies
possible carb swap
Has anyone here tried using a jet ski carb on a classic triumph?
We have a few of the old 2 stroke 550 stand up jet ski parts in the shop. They were going to go to the scrap metal yard, until I took another look at the carbs. They are styled like a chain saw carb. There is no float bowl. Instead there is a fuel diaphragm, that pumps gas, using crankcase pressure. They are downdraft carbs on the skis, but there is no reason they cannot work as side draft carbs
The odd thing is that one of them looks like it will bolt right up to my 71 TR6 intake. I am really thinking of drilling out a timing plug, and tapping into crankcase pressure there
Lee H is offline   Reply With Quote
Old 07-19-2012, 12:06 AM   #2 (permalink)
Main Motorcycle: '98 Thunderbird
Other Motorcycle: Wife's '95 Thunderbird
Extra Motorcycle: '99 Sportster 1200 Sport
I've seen snowmobile carbs crossed over before but jet ski would be the first.
Guess it would even run upside down too. Hay, may be a good app for a stunter.
If I don't know the answer, I just make one up!
Mr Bentwrench is offline   Reply With Quote
EFI to Carb swap possible? mrbrice Twins Technical Talk 6 04-17-2011 10:06 PM
2 Minute Carb Swap... englane Twins Technical Talk 8 02-07-2010 03:58 PM
Carb Swap? threepot T3 Sport / Touring Forum 16 12-03-2007 01:37 PM
Amal carb swap flyrodder Classic, Vintage & Veteran 1 08-04-2006 01:29 AM
Carb swap for Big Bore MaxH Twins Talk 1 05-26-2006 11:14 AM
