carbon fouled plugs - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 9 (permalink) Old 07-15-2012, 08:45 PM Thread Starter
Main Motorcycle: 72 T120V
Other Motorcycle: 65 T120R
carbon fouled plugs
Suggestions about how to proceed in tracking down the cause for carbon fouling the plugs on my 72 Bonneville? It is a recent problem....plugs foul out after only a few miles of riding. I drained the tank, installed lower octane fuel, but the fouling continues. Any ideas? Mike G
mgrosso is offline
post #2 of 9 (permalink) Old 07-15-2012, 09:20 PM
Main Motorcycle: 70 T120R Bonnie
shrugger's Avatar
Other Motorcycle: 72 Norton Combat
Extra Motorcycle: Royal Enfield Bullet 500
Please add your location. How Octane is rated differs across the world.
In N.America NO lower than 91. 93 is best if it's available in your area.
It's not likely a fuel problem but a Carb problem. The air screws should be your starting point.
You might find this helpful.
http://www.jba.bc.ca/Bushmans%20Carb...g.html#SYNCHRO
"Thanks to denial, I'm immortal" -Phillip J. Fry
shrugger is offline
post #3 of 9 (permalink) Old 07-15-2012, 09:53 PM
TE Lifetime Contributor
Main Motorcycle: Rickman T120
Other Motorcycle: T160,TR6
Low-octane fuel is not a great idea.It will still run rich,but you could now burn a hole in a piston crown,from detonation.
It could even run slightly richer with low-octane fuel.
The most likely cause of richness is dirty air filters or worn needle-jets.The needles don't wear much,and the parallel part should measure 0.0985" diameter.The jets are usually worn out at 10,000 miles,and a worn jet causes richness.It's not so easy to measure the diameter of a needle-jet.A 106 needle-jet should measure 0.106" in the orifice.If it measures 0.1065",it's worn out.
Mr.Pete is offline
post #4 of 9 (permalink) Old 07-16-2012, 07:57 AM
Rev
Main Motorcycle: T 160 Trident
Other Motorcycle: BMW K1300 R
Extra Motorcycle: 66 Bonnie
As mentioned, check your carby settings to eliminate mixture & synchronisation issues. How old are the coils ? How good is the spark?
Rev is offline
post #5 of 9 (permalink) Old 07-16-2012, 09:46 AM Thread Starter
Thumbs up carbon fouled plugs
The bike is being ridden in the MidAtlantic region and used high octane successfully until til this recent problem. I'll go through the carbs next and look for issues there. Thanks to all who replied.
mgrosso is offline
post #6 of 9 (permalink) Old 07-17-2012, 01:31 AM
Main Motorcycle: 5T 1958 SPEED TWIN
pre unit Thruxton's Avatar
Other Motorcycle: 1959 Triumph Bonneville
Send a message via Skype™ to pre unit Thruxton
[QUOTE=shrugger;2301354]Please add your location.
Where You at? Where you from?????????
Check float height and carb settings ------ Its tooooooooooooooooo Rich.................
Make sure you using the correct plug!!!!!!!!!!!!!!!!!
pre unit Thruxton is offline
post #7 of 9 (permalink) Old 07-17-2012, 10:19 AM Thread Starter
carbon fouled plugs
Went through carbs, cleaned pilot jet, blew out main jet, checked float, checked dual carb cables for synch action. Someone suggested the air slide could be hanging up, but it appears to move freely with the cable. Can anyone please explain its proper operation? Air slide fully up means.....? Slide fully down means? Thanks for all your replies.
mgrosso is offline
post #8 of 9 (permalink) Old 07-18-2012, 05:20 AM
Air slide fully down means you're choking it and making it very rich.
Air slide fully up for normal operation on a warm engine.It should be right up inside the throttle slide.
Mr.Pete is offline
post #9 of 9 (permalink) Old 07-18-2012, 09:26 AM Thread Starter
Thanks.....I really appreciate all your help.
Mike G
mgrosso is offline
Carbon Fouled Plugs bikeman71 Classic, Vintage & Veteran 12 06-25-2012 06:58 AM
Fouled plugs Binky Tremain Air Cooled Twins Technical Talk 1 05-11-2012 12:09 AM
fouled plugs lvmp42 Hinckley Classic Triples 14 08-01-2008 11:22 PM
Fouled plugs eh? Herbus Speed Triple Forum 2 07-26-2008 01:47 AM
2001 bonneville carbon fouled plugs 64roberto Air Cooled Twins Technical Talk 4 05-19-2007 12:39 PM
