Old 12-14-2005   #1 (permalink)
X75 Hurricane. Hasn't been started in around15 years. Wasn't prepped for storage although was in a garage. Need help getting it running. any advice is appreciated.
"The Glory of God is man fully alive."
narrowminded is offline   Reply With Quote
Old 12-14-2005   #2 (permalink)
ooobaby's Avatar
Sounds like a lot of work! Sell it to me for say $500.00 and I'll save you all that trouble. :razz:
ooobaby is offline   Reply With Quote
Old 12-14-2005   #3 (permalink)
Add a zero just to the left of the decimal point and you have a deal.
Old 12-14-2005   #4 (permalink)
T500D
Narrow,
You might try this site.
www.triplesonline.com
The basics, of course. Freash gas, oil, clean the sludge trap under the motor. If it still has points, it'll be a tough road. I chucked the points ASAP for a Boyer. Triples are finicky with the valves. Hard starting if you don't have it right. The Amals will need some attention. Get a manual!! You'll need it. Go to the above site, ask questions, search the archives. We all have Meriden triples, and we're all only too happy to help a newby get another one on the road!
Cheers,
Troy
Old 12-15-2005   #5 (permalink)
Moderator
Favorite Bike: Triumph Bonneville
Other Motorcycle: Britiron
The usual MINIMUM stuff:
Flush all oil and gas, including fork oil & tranny, primary, etc.
Pull the carbs and soak in 1-gallon can of Berryman's Chem Dip for 20 minutes - METAL PARTS ONLY. Hand-clean floats and replace all o-rings & gaskets with new kits.
Tear apart disc brakes and flush all old fluid, use brake parts cleaner to freshen everything up, install new o-ring kits, re-assemble and use modern brake fluid.
New battery.
Check the tires close, replace if rot cracked (likely).
Good to go.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photos
Happiness is a fresh frame Tig66208 Classic, Vintage & Veteran 5 02-02-2008 12:57 PM
fresh pics Mesoam Speed Triple Forum 24 07-31-2007 10:54 AM
fresh paint FuryFour Triumph SuperSports 2 12-30-2006 05:52 PM
A couple fresh pics SCCTrim Twins Talk 23 09-14-2006 01:09 PM
Fresh and official news: How many Rockets? mikekeane123 The Rocket Science Forum 2 07-05-2005 10:22 PM
