Motorcycle.com
Old 04-13-2004   #1 (permalink)
just bought a 1976 T140, with out bat, i need to know which wire goes to the rectifer, ground or hot.
thanks a lot for any help
paul
Old 04-13-2004   #2 (permalink)
Favorite Bike: 98 Thunderbird
Ground.. They have a positive earth system.
Old 04-13-2004   #3 (permalink)
Ground does go to the rectifier but what about the other terminals?
The rectifier has 4 terminals. Two wires go to the alternator; one wire to earth and one wire to the battery negative.
If it's the original Triumph rectifier then earth is the central stud, the battery negative is the terminal below it and the alternator conections are either side.
Old 04-13-2004   #4 (permalink)
I would highly recommend you grab a Haynes or Clymer manual as well. You will find that these bikes require a lot of care and maintenace and the $20 (or so) spent on the book will pay for itself quickly in reduced headaches and (occasionally costly) mistakes.
Trumpets4Years is offline   Reply With Quote
Old 04-14-2004   #5 (permalink)
The books do help I just bought 1976 T140 my self. But the guy threw in the books.Ilook for word to hearing how you make out getting it running.Mine needs alot of work. rod
Yol Bolsun
May there be a road.Rod
Klicker is offline   Reply With Quote
67 bonnie wiring problems jackson Twins Technical Talk 8 07-21-2007 10:22 AM
Wiring photos/'67 Bonnie jackson Classic, Vintage & Veteran 1 07-18-2007 10:55 PM
Bonnie wiring question kawtoy Classic, Vintage & Veteran 2 04-11-2006 07:27 PM
'69 Bonnie wiring beegee Classic, Vintage & Veteran 2 09-17-2005 09:24 PM
72 bonnie wiring problems buggy Classic, Vintage & Veteran 3 07-23-2004 03:28 PM
