Should I replace clutch hub with later model? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-27-2012, 12:44 PM   #1 (permalink)
Main Motorcycle: '68 TR6R
68TR6R's Avatar
Other Motorcycle: 1978 suzuki 125
During my last ride, my clutch suddenly began to slip rather severely. No weird noises or anything, and when I pulled the primary everything looked fine. Turns out that two of the three screws that hold the inside plate of the clutch hub came loose, allowing the hub to slide out a bit and causing the first steel plate to actually slide behind the hub. The threads are no good anymore. So instead of fixing the threads, is it worth it to buy a later model hub that used through bolts instead of 6 small screws? such as this: http://www.ebay.com/itm/57-4435-Triu...90b0f8&vxp=mtr
Life's tough.......Get a helmet
68TR6R is offline   Reply With Quote
Old 05-27-2012, 12:53 PM   #2 (permalink)
Main Motorcycle: 70 T120R Bonnie
shrugger's Avatar
Other Motorcycle: 72 Norton Combat
Extra Motorcycle: Royal Enfield Bullet 500
That should work fine. If it's only the screws threads that are trashed. You can buy
new one's. Use Loctite blue when putting them in. That will be enough to keep them in.
"Thanks to denial, I'm immortal" -Phillip J. Fry
shrugger is online now   Reply With Quote
Old 05-27-2012, 08:19 PM   #3 (permalink)
68TR6R's Avatar
When I put it together a few years ago, I used red loctite, but it's the threads in the hub that are bad unfortunately.
The two screws were in the bottom of the clutch basket, and the third was loose. Luckily, they didn't do any damage.
Old 05-28-2012, 02:46 AM   #4 (permalink)
Moderator
Main Motorcycle: Rickman T120
Other Motorcycle: T160,TR6
A 6-screw cush drive would be getting old by now.The journals and plates are probably worn and running out off-centre.
The through-bolted 3-bolt cush drive is more reliable,and a worthwhile up-grade.
Mr.Pete is online now   Reply With Quote
Old 06-03-2012, 12:40 AM   #5 (permalink)
68TR6R's Avatar
I replaced the rubbers during the last rebuild (20,000 miles ago) and I didn't have any problems with the screws. It's the original hub, which has around 70,000 miles, and I did notice that it didn't run quite true. I think it's just worth it to replace.
Thanks for the advice.
Time to replace the clutch? pineygroveshop Tiger Workshop (archive) 5 06-19-2010 05:25 PM
'00 Clutch cover gasket - hard to replace? scritch Sprint Forum 1 02-24-2010 07:00 PM
Replace Clutch Cable Rudcluti Sprint Forum 7 08-24-2009 12:41 AM
Have you had to replace your sprag clutch? Rollme Twins Technical Talk 5 07-17-2008 03:42 PM
How to replace a clutch cover jsek29 Speed Triple Forum 3 01-16-2007 09:37 PM
