Triumph engine rebuild? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 5 (permalink) Old 04-13-2012, 03:31 PM Thread Starter
Main Motorcycle: Thruxton
Glassmann024's Avatar
Hello Y'all , I want to buy an old triumph engine to teach myself how to do a rebuild and then use the engine in a hard tail bobber project. Can I get some opinions on weather I should start with a 650 or 750 ? Pre unit or unit ? Most importantly , what is a reasonable price to buy an engine that needs a rebuild? I live close to Rabers in San Jose so parts ,help, and knowledge are close .
Thanks for your time.
Glassmann024 is offline
post #2 of 5 (permalink) Old 04-13-2012, 04:05 PM
Main Motorcycle: T140 E
If it was me, I'd use a 750 from an oil in frame as they seem to be less valued than the earlier bikes.
I don't know if you've ever built a bobber, but the cheapest way of getting a job done (I'm told) is to buy a whole bike that maybe needs work, or has had a prang. That way you'll get the wheel, forks, brakes and engine and sourcing parts is easier if the whole bike started say, as a 76.
The OIF can make a nice bobber - or go earlier if you want a "normal" frame - unless you plan to build one
Generally, the bikes got better - the early OIF had a high frame
DAVE M is online now
post #3 of 5 (permalink) Old 04-13-2012, 04:31 PM
Main Motorcycle: 1978 T140v
Other Motorcycle: 2010 Bonneville
There is a premium for pre OIF frames. I would not look for that. I would do a unit 750. As Dave said less value. Also there are some great video out there by Four Aces. Specifically a rebuild video that shows you all the steps to tearing down an engine and putting it back together. Also youtube lunmad.
arbeach is offline
post #4 of 5 (permalink) Old 04-13-2012, 04:51 PM
Legend
The answer seems obvious to me: go down to Raber's and ask what's the best deal on a complete engine that is guaranteed to have all the core parts rebuildable. I'm sure they'll aslso cut you a fair deal on all the overhaul parts, as you will already be dropping a significant chunk of change for the scruffy lump.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
GrandPaulZ is online now
post #5 of 5 (permalink) Old 04-14-2012, 06:08 AM
Main Motorcycle: T120V
Caulky's Avatar
Other Motorcycle: 1960 Tiger Cub
Extra Motorcycle: 1971 Bsa A65L
If it wasn`t a bobber project, I`d go for a late unit 650.
These were tuned more for performance, regardless of the environmental consequences.
Bear in mind the gearshift side changed from R/H to left about 1975.
And the 5-speed box appeared in 1973-ish.
I like 650`s, so I`m a bit biased.
Caulky is online now
1981 Triumph T140ES2 Engine Rebuild? indianrider Classic, Vintage & Veteran 15 11-21-2011 03:44 PM
Triumph EFI Engine Rebuild Jasbel Air Cooled Twins Technical Talk 3 05-02-2011 08:41 AM
Triumph 650 engine rebuild DVD Snakeoil Classic, Vintage & Veteran 10 03-06-2009 09:57 PM
02 Triumph TT600 engine rebuild binglax09 Triumph SuperSports 6 05-27-2008 09:51 PM
need engine rebuild Classic, Vintage & Veteran 3 04-15-2004 05:15 PM
