Motorcycle.com
Old 11-20-2005   #1 (permalink)
sllim
I am trying to dismantle my T100R trans. I have the clutch apart down to the nut before the trap door cover plate. I have read my manual over and over but this nut isn't specifically addressed. I have tried my puller on it but it won't budge. I have used penetrating oil on it and pounded on the puller shaft to break the nut free but no luck. This nut holds the keyway. Am I missing something? Is this nut supposed to pull off? It is threaded on the inside where the keyway nut is. Look here for an image of the nut.
http://www.zerosquadron.com/triumphtech101.pdf
Top image on page 14.
Thanks.
Brian
[ This message was edited by: sllim on 2005-11-20 16:54 ]
Old 11-21-2005   #2 (permalink)
vik
Shouldn't that be page 12 ? Anyway that is not a nut I think but just the clutch center. As indicated you should be able to pull that off, and it is NOT threaded. This hasn't posed a problem on one of my engines yet, so anyone else have some ideas ?
Maybe some previous person working on it used something extra to fix it real tight, Loctite perhaps, or an extra fixing somewhere ?
Triumph or Die
vik is offline   Reply With Quote
Old 11-21-2005   #3 (permalink)
sllim
Got it...Bought the biggest hammer I could find and gave it a wack...off it came.
Thanks,
Brian
[ This message was edited by: sllim on 2005-11-21 12:33 ]
Break in done Shaunlee Speed Triple Forum 3 09-02-2007 07:52 AM
break in tyson Speed Triple Forum 9 04-14-2007 01:30 PM
Break in? Lono Speed Triple Forum 26 05-21-2005 06:27 AM
break-in? LtJake Modifications & Workshop Talk 10 03-05-2005 07:33 AM
Triumph break-in vs. Motoman's break-in? Triumph SuperSports 3 07-14-2004 06:58 PM
