Old 11-18-2005   #1 (permalink)
I was thinking about a project bike down the road. I want to do a vintage (68-74?)650 or 750 in cafe trim. I really don't have any experience with the Triumphs made before 96.
Are there any good books or other reference material to begin with (Roy Bacon)?
Are there any years/engine/trannys that may have unique challenges that a first time restorer should avoid?
Zip
"You don't know what you don't know."
zippythehog is offline   Reply With Quote
Old 11-18-2005   #2 (permalink)
vik
If you like the project bike and it looks ok with the right price tag, just take the dive and make the link with history.
I don't find much use in reading general literature first, you will certainly need the workshop manual for your model anyway, either the original Triumph one, the Haynes or both. Don't think Baycon bothers much with Caféracers anyway, more with originals.
But the workshop manuals will learn you plenty. There are sites on the net that allow you through the VIN number to identifiy the model you have your eye on.
Triumph or Die
vik is offline   Reply With Quote
Old 11-19-2005   #3 (permalink)
The early (71 thru 73) oil in frame models have some interesting quirks.
The dreaded shift quadrant detent leaf spring, the 'comical' conical drum brake, and the 'too high to ride frame' in 71&2.
Some of the early 5 speed gearboxes (72&3?) had mistempered gears that chipped, broke, snapped, and shattered if used hard. Or sometimes if used at all.
The styling is, well, ugly, when compared to previous years.
They're looked at like bastard stepchildren by some (many? most?) hardcore Triumph resto enthusiasts.
This makes 'em relatively cheap, readily availible, and perfect candidates for any sort of modification
oilyboot is offline   Reply With Quote
Old 11-21-2005   #4 (permalink)
If your interested in something that is already good-to-go, take a look at mine.
Sammi
Sammi is offline   Reply With Quote
Old 11-21-2005   #5 (permalink)
Oilyboot,
If/When the gears shatter, is there usually collateral damage associated with it (chuncks of metal floating through the engine) or are these non-unit?
Did Triumph get away from the oil in frame set up after a period of experimentation with it?
Sammi,
You're the original owner? What are you looking to get for it? I probably can't afford it but it would be a good reference for me.
Old 11-22-2005   #6 (permalink)
The gearbox is self contained in both 'pre unit' and 'unit' construction models. No shared oil (or chunks) on either type.
The bad batch of early 5 speeds disintegrated very quickly in use. Any still on the road today has -most likely- been refitted with proper gears.
Triumph went OIF with their 'big twins' in '71. AFAIK, they never went back.
If you're actually going to ride it rather than just admire it, the OIF models are a better choice for a cafe racer, imho.
Old 11-22-2005   #7 (permalink)
Zippy,
I sent you a pm with the details.
Just post here if you did not receive it.
Sammi
Old 11-22-2005   #8 (permalink)
yeah , the early 5 speeds with that spring metal leaf spring in the transmission is triumphs little joke . i have one of the first 5 speeds , i've never had gears fly apart , but getting the transmission back in with the leaf spring was a pain in the ass .
TheBondoBandit is offline   Reply With Quote
Old 11-22-2005   #9 (permalink)
Yes, Sammi, I got the pm. I am looking for something that needs more loving attention (and is correspondingly cheaper).
Oilyboot, what does unit construction mean?
Old 11-22-2005   #10 (permalink)
Favorite Bike: 1970 TR6 Spring Gold!
It refers to the engine. In the early triumphs the gearbax was separate from the engine. These were referred to as pre-unit construction. Sometime in the 60's (I forget when) Triumph change the engine to the unit construction model where the gearbox was incorporated into the engine case. In my opinion the pre-unit cases look prettier, but I've never worked on one.
Someone out there can tell us why they did it.
Hey, What's this oil on the floor?
quagmire is offline   Reply With Quote
In serious need of advice darcon T3 Sport / Touring Forum 14 05-27-2007 07:14 PM
I need some advice merlotlover Twins Technical Talk 7 04-12-2007 07:12 PM
Any advice? Freakazoid84 Sprint Forum 2 04-30-2006 08:45 AM
Need some advice FDCF1 The Rocket Science Forum 2 08-21-2005 10:42 PM
Need Some Advice muss Twins Talk 6 08-15-2005 10:12 AM
