hey jtrip... i think several aftermarket oil filters are available for our bikes....but $$$...also i think most reroute oil lines outside the frame, to a remote location..hampering original look (not sure but i think thats how they do it ) ..anyway, i made my own, i went to auto zone and picked up a stp smo-04 motorcycle filter wich is very close in size to that wire screen filter (how good can that be ? ) i duplicated the bottom plate , then i machined a couple dimples in the inside to accept 2 small rods about 2 in tall...a quick spot weld holds these...on each side of the filter..then i made a small flange to fit over the filter and rod ends wich i threded ...next a couple nylock nuts hold the filter down...that way i have a replaceable modern oil filter...instead of that wire screen...if i knew how to post a pic i would....ill send u a pic if u want...i work in a machine shop so i can do all this myself...i posted this a few monthes ago .....but nobody seemed intreasted so i dident bother to learn how to post a pic....gimme ur e-mail...or tell me how to post a pic here and i wil .....tom
Ward...dontcha think you were a little hard on "the beaver "last night!!!
