Headlamp Switch Wiring Question 1971 T100c - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 5 (permalink) Old 03-03-2012, 11:52 PM Thread Starter
Main Motorcycle: '03 Bonneville
TheFixer's Avatar
Other Motorcycle: 1971 Triumph Trophy
Hi all. Finally closing in on the finishing steps of of 1971 T100c rebuild. I've consulted my maintenance manual, Haynes manual, & Building British Bikes books and I am still not 100% confident on this one. Need some wiring help, please.
I purchased a reproduction harness to replaced the crusty "and modified" loom that came with the bike.
My 3 position headlamp switch has 6 spades instead of 8 like the wiring diagram suggests.
1 2
3 4
5 6
I have four wires with connectors in the headlamp shell:
Brown/Blue = ignition
Brown/Green (double wires) = speedo/tail lamp
White/White (double) = ignition
Blue/Blue = headlamp
I don't have a red/black wire as the manual suggests for 4. But, it appears he pilot bulb shares the same wiring (brown/green) as the speedo/tail lamp. I suspect the pilot wire (red/black) in the manual isn't required since the pilot will now be powered at the same time as the speedo/tail lamp?
I cannot find a double white/white referenced anywhere in my manuals though and am at a complete loss on this one.
I think it should be:
1:No wires
2:Brown/Blue = ignition
3: No wires
4:??
5: Brown/Green = speedo/tail lamp
6: Blue/Blue = headlamp
Can someone confirm if this is correct?
My '03 Bonnie: Custom paint (c. 1964), Eyebrow Badges, Hagon Progressive Springs, Hagon 2810 shocks, NH Togas, NH Belmouth + K&N Filter, Custom Seat, Fork Gaiters, BC Western bars, vinatge mirrors, early 60's license plate bracket + custom lighting.
TheFixer is offline
post #2 of 5 (permalink) Old 03-04-2012, 08:41 AM
Main Motorcycle: 1973 TR7RV "in prep"...
Other Motorcycle: Ducati SportClassic 1000
Extra Motorcycle: Ducati Monster 695
White wires should mean "switched power from ignition switch" that is they only carry power when ignition is on. Check that is the case.
Brown/blue wires should mean "always live" Check that is the case.
These headlamp switches are pretty simple and you need to check that the three positions provide the following;
Position 1 = nothing. Terminals 1 and 2 are connected but there are no wires going to either so nothing happens, everything off.
Position 2 = Pilot and Tail. Terminals 3 and 4 connected. Brown Blue to terminal 3, Brown/Green to terminal 4.
Position 3 = Headlamp hi/lo AND Pilot and tail. Terminal 3 and 4 and 5 and 6 connected. White to terminal 5 Blue to terminal 6.
You might find that Position 3 does NOT connect terminals 3,4,5 and 6 together. If that is the case you will have to make a wire to connect terminal 6 to terminal 4 to provide current to the tail light when the switch is in position 3.
You need to get your multi meter out to work out what is happening inside your switch then draw it out on paper. before you start wiring it up. That works for me.
Good luck.
Adam.
http://tiger750.wordpress.com/
Please support The Ruby Lambert Trust:
http://www.one4ruby.com/
Triumph5ta is offline
post #3 of 5 (permalink) Old 03-05-2012, 08:29 AM
On all Triumph looms I have seen the double white wire is doing two things:
It is bringing power from the ignition switch to the headlamp switch from where it is passed to the headlamps.
It also sending power onwards, independent of the headlamp switch, to a front brake light switch. If you do not have a front brake light switch do not worry about it.
Adam.
post #4 of 5 (permalink) Old 03-05-2012, 09:03 AM Thread Starter
TheFixer's Avatar
Thanks T5ta. I do not have a front brake light switch on mine. I have it wired now per your suggestion - just need to test it. I'll let you know it goes when I get it sorted out. Appreciate the input.
TheFixer is offline
post #5 of 5 (permalink) Old 04-04-2012, 09:52 AM Thread Starter
TheFixer's Avatar
Issue solved!
I finally got this issue sorted out. The 3 position switch that the PO had installed was not wired in a way that was compatible with the original design. Using a multimeter I was able to determine that POS 1= On A, POS 2 = Off, POS 3 = On B. Because of this set up, I had of choice of either having the tail light/instruments on OR the headlights on, but not both.
I ultimately replaced the switch with a reproduction of the original. My reproduction wiring harness differs slightly from the original as it has integrated the headlight bucket wiring and the main harness into one complete loom. Becasue of this, I had to deviate slightly from the original wiring diagram. The image below shows the end result which is now working properly.
The only issue is that because the Brown/Blue wire is connected to the switch and it is always on, the lights will power on in POS 2 (tail/instruments) and POS 3 (tail/instruments + headlights) without the ignition being turned on. The only way to avoid this is to exclude that wire from the switch completely.
One last thing: My '71 does has a front brake switch. I misspoke in my last post.
TheFixer is offline
1971 T100C Trophy top end rebuild toxic Classic, Vintage & Veteran 27 10-04-2015 07:37 AM
1971 Trophy T100C - aboutadog The Welcome Center 5 09-24-2010 04:20 AM
1971 T100c Fuel Question TheFixer Classic, Vintage & Veteran 6 05-07-2010 08:09 PM
Wiring help in headlamp and ignition switch Kev_England Classic, Vintage & Veteran 62 01-14-2010 12:48 PM
t100c 1971 LegendTT99 Classic, Vintage & Veteran 1 02-14-2007 04:24 PM
