930 Amal MK1 upgrade (Premier) - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 14 (permalink) Old 06-16-2011, 04:18 AM Thread Starter
Main Motorcycle: '72 Bonneville
RetroRod's Avatar
Other Motorcycle: Suzuki GSX1400
To those contemplating new MK1 Amal carbies.
I ordered 2 new 930 concentrics from Amal and received the following offer to upgrade to their new Premier version. I have accepted by the way!!! Looking forward to fitting them to the old tart. RR
"I am writing to customers ordering 30mm Mark 1 carburetters because we will shortly be introducing an improved version of the Mark 1 Concentric carburetter for four stroke use which we call the Premier version. It includes all the recent upgrades such as hard anodised slide, Stay-up float and aluminium needle valve. It has also been modified to use a new design of pilot jet.
The new jet screws into the body in the opposite position to the pilot air screw and replaces the pilot bush previously used. This positions the jet in the same position as the pilot bush and in the optimum location for four stroke use. The jet can easily be removed for cleaning and has been designed to tolerances so close that the jet can be replaced if required without the need to re-tune the idle circuit. Everybody who has used the new carburetters so far have reported noticeable improvements in idling and low speed running. Mileages of up to 1500 miles have been reported so far without problems.
The carburetter is currently available in 30mm only for £116.00 plus shipping (and VAT if applicable) with a 2 year guarantee. This is a preliminary offer because in exchange we would like to hear any feedback you may have on how the carburetter performs."
You have enemies? Good. That means you've stood up for something, sometime in your life. (W S Churchill)
RetroRod is online now
post #2 of 14 (permalink) Old 06-16-2011, 04:53 AM
Main Motorcycle: T120V
Caulky's Avatar
Other Motorcycle: 1960 Tiger Cub
Extra Motorcycle: 1971 Bsa A65L
Looks good Rod.
I like the screw-in pilot jet.
Time to upgrade???
Caulky is offline
post #3 of 14 (permalink) Old 06-17-2011, 08:03 AM
Main Motorcycle: Triumph Tiger TR7RV
Does this mean the end of poking around with guitar strings then?
BonneFire is offline
post #4 of 14 (permalink) Old 06-17-2011, 09:35 PM Thread Starter
RetroRod's Avatar
Guitar strings may well become redundant one day. RR
post #5 of 14 (permalink) Old 06-17-2011, 11:20 PM
Main Motorcycle: '59 thunderbird
Other Motorcycle: '95 Thunderbird
Originally Posted by RetroRod View Post
... noticeable improvements in idling and low speed running. [/I]
I hope that for your 200 odd quid you get your twin carbs to idle as well as my single Monobloc.
Certainly sound like nice carbies.
Cheers,
Neil.
loctitekid is offline
post #6 of 14 (permalink) Old 06-13-2013, 09:34 PM
Main Motorcycle: 1972 Triumph Tiger TR6R
Eco Loco's Avatar
What Can I Expect?
Hi guys,
I actually just ordered a 930 premier but before I bolt it on I was hoping I could get some advice from the group. My concern is as follows: for a 1972 TR6R, the book says 3 1/2" slide is what I need. But, the new 930 premier doesn't seem to be available for purchase with a 3 1/2" slide. It seems like I have to buy the carb with a 3" slide then purchase the 3 1/2" slide separate (which is another $50). I'm wondering-all things being equal--what I can expect in the way of idle/performance if I run the new carb on my Tiger with a 3" slide rather that the 3 1/2" slide the book calls for.
Thanks!
Eco Loco is offline
post #7 of 14 (permalink) Old 06-13-2013, 11:23 PM
TE Lifetime Contributor
Main Motorcycle: Rickman T120
Other Motorcycle: T160,TR6
You can expect a rich mixture,especially at just under 1/4 throttle.
Just file the cutaway 1/32" bigger.Change the angle to make it a 3-1/2 slide.
Mr.Pete is offline
post #8 of 14 (permalink) Old 06-14-2013, 06:14 PM
Main Motorcycle: 1971 t120r
rambo's Avatar
Other Motorcycle: triumph rocket 111
Extra Motorcycle: BSA Spitfire
The premier carb is built with the components you request to be fitted,there is no extra charge at all from proper suppliers.i just bought a pair with the parts I wanted fitted.They were bolted on,air screw set at 1 turn out,tickover established,and then up the road after a first kick start.running better than its ever run.I had replaced a set of MK1s that were 10 years old.Perfect and worth the £260 a pair I paid
rambo is offline
post #9 of 14 (permalink) Old 06-14-2013, 09:30 PM
JTT
Main Motorcycle: 1970 T100C
JTT's Avatar
Other Motorcycle: 2005 KLR650, 2003 Tiger
I agree. I just put one on my T100C. Brilliant! Wish I had done this years ago. You won't regret.
JTT is offline
post #10 of 14 (permalink) Old 06-14-2013, 11:18 PM
Main Motorcycle: 1967 T120
Ken Reece's Avatar
Other Motorcycle: 1966 Ducati Mk3 Diana
Amal Premier Carbs
I have to agree with those who have posted positive results after fitting these. I had been chasing uneven idle and mixture variation with my old carbs which were original. I replaced everything short of re-sleeving. I did the math on throwing more money at the old carbs, or just buying the premiers. I am so happy I did. My guess is that buying the old standard Amal Mk1s would have produced the same result, but the hardened slides of a new alloy and the stay up floats are realy reasonable upgrades worth paying a bit extra for. We should count ourselves fortunate that we can buy these over the counter brand new at such reasonable prices. Many other vintage bike owners have to go the re-sleeve and repair route or spend big bucks for mint or NOS spares.
Ken Reece is offline
English Premier League: who will come first? Haggis Biker Hang-Out 20 03-23-2010 10:30 PM
Triumphs on Alias Season Premier TripleThreat Sprint Forum 7 01-06-2005 02:32 PM
Triumphs on Alias Season Premier TripleThreat Speed Triple Forum 7 01-06-2005 10:07 AM
Triumphs on Alias Season Premier TripleThreat Triumph, Models & Dealers 3 01-06-2005 01:20 AM
