I got the bike running today, good news... :-)
Oil leaking from primary case.... bad news :cry:
The book says 5/8 Imp pint. So I converted to US and came up with 12 ounces. I put in the oil. It did not come close to the cap in the center of the cover but I figured I'd start with the 12 ounces and see what happened.
Well the oil is "pumping" out of what looks like a breather hole. The hole is located just above the rear-most bolt on the back side of the primary. The oil only leaks when the engine is running.
Anyone have any info that might help ?
Thanks,
Allan
