Trident-Exhausts.comBikeBanditAdvanstarMotorcycleShows
ShopTriumph.com
Old 09-07-2005   #1 (permalink)
dirk
Hi, I am posting this question for a friend. We have a '70 TR6R with a 4 speed tranny. We are trying to replace the 4 speed with a complete 5 speed tranny from a Bonneville. The questions are: What mods need to be done? What parts are needed? Any mods necessary to shifting mechanism? Are the inboard transmission cover/case different? The 5 speed transmission was installed on the bench and it does not shift.
I appreciate any insight or experience in making this conversion that you guys can give us.
Thanks.
Old 09-08-2005   #2 (permalink)
Victory Library covers the details nicely.
http://www.triples.demon.co.uk/artic...ticles/4-5.htm
oilyboot is offline   Reply With Quote
Old 09-08-2005   #3 (permalink)
Favorite Bike: 1971 t120r
Other Motorcycle: triumph rocket 111
Extra Motorcycle: suzuki m1800r
hi dirk,
with the power of a 650 being delivered at low revs,it did not need a 5 speed box.they have enough torque low down not to need it.the 750s needed 5 gears as power was developed higher up the rev range.it was also added just because the japanese did it.
i think you will find that in an acceleration race,with having an extra change,the 5 speed will slow you down.
best improvement is to change the 19 tooth chain sprocket to a 20 tooth....cheers :hammer: :hammer:
rambo is offline   Reply With Quote
Old 09-08-2005   #4 (permalink)
dirk
THANKS a lot for the info. I will pass it along to my friend.
Daytona 955i speed triple conversion!! Flat6 Daytona Deliberations 4 06-08-2007 09:46 AM
Daytona 955i to speed triple conversion. Flat6 Speed Triple Forum 6 06-01-2007 10:19 PM
5 speed conversion dirk Twins Talk 2 09-07-2005 10:55 PM
95 Speed Triple handlebar conversion Nic900 Modifications & Workshop Talk 2 06-29-2005 10:02 PM
Six Speed Conversion rwven Speed Triple Forum 1 06-15-2004 06:44 PM
