flushing oil - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 40 (permalink) Old 02-19-2011, 11:54 AM Thread Starter
Main Motorcycle: `71 TR6R
Other Motorcycle: `73 TR7RV
Extra Motorcycle: 2005 Ducati 999
flushing oil
Can anyone explain what flushing oil is and how it is used and what the benefit would be?
MoBe is offline
post #2 of 40 (permalink) Old 02-19-2011, 01:42 PM
Main Motorcycle: The one between my legs
Snakeoil's Avatar
Other Motorcycle: A few
Extra Motorcycle: Yes
So many straight lines and so little time...
Snakeoil is online now
post #3 of 40 (permalink) Old 02-19-2011, 02:16 PM
Main Motorcycle: 1982 TSS + 2011 Tiger 80
epynt1050's Avatar
Other Motorcycle: 82 TR65, 69 T120 73T100R
Extra Motorcycle: 08 Street Triple, 1913 "A
Used to be normal practice to flush the engine out at an oil change. Flushing oil is a light oil with a lot of detergent in it. You drained the old oil hot. Refilled with flushing oil and ran the engine for 5-10 minutes under no load conditions and the engine at tick over or slightly above. After running, you just drain the flushing oil. It comes out absolutely black. A second application might be necessary if the engine has not been flushed for some time. Leave to drain well. You then just put in your normal low detergent 20w-50. Flushing oil is designed for classic engine without in-line filters such as Triumph twins.
Flushing oil is designed to "lift" any crud in the engine and hold it in suspension so that when you drain the oil, he crud comes out with it. Ideal for engines such as Triumphs as it should clean out the sludge trap provided the crud has not become too solid.
Widely used in the UK in the 50's and 60's by the typical owner/mechanic (most of us could not afford to use a dealer). Cannot remember anyone talking about the "sludge trap" as being an issue. Seems to be a US thing and I suspect the reason being that Flushing Oil was not in common use in the USA.
Flushing Oil was unobtainable for many years but is now available again. See http://www.morrislubricantsonline.co...p?idproduct=80
epynt1050 is offline
post #4 of 40 (permalink) Old 02-19-2011, 04:26 PM Thread Starter
Thanks for the answer epynt1050,I`d like to ask another question.
The workshop manual states that if flushing oil is not available ,kerosene can be used.
What is your opinion on the use of kerosene?
MoBe is offline
post #5 of 40 (permalink) Old 02-19-2011, 06:22 PM
Snakeoil's Avatar
Personally, I'd be concerned about using kero for anything but filling and draining again. It does have some lubricative properties, and certainly has solvent properties. But I'd be wary about running the engine with Kero in the crankcase. To me, it seems too light to produce a decent oil wedge in any plain bearing.
I would think that with today's modern detergent oils, flushing oil is really not required. Weren't the straight weight oils used in bikes back in the 50's and 60's non-detergent? That would make cleaning out the sludge a requirement I would think.
regards,
Rob
post #6 of 40 (permalink) Old 02-19-2011, 07:23 PM
Main Motorcycle: '72 Bonneville
RetroRod's Avatar
Other Motorcycle: Suzuki GSX1400
regards,
Rob
That would be right Rob. RR
You have enemies? Good. That means you've stood up for something, sometime in your life. (W S Churchill)
RetroRod is offline
post #7 of 40 (permalink) Old 02-19-2011, 07:32 PM Thread Starter
Personally I can`t for the life of me see using kerosene,the feeling being that it would actually do more harm than good.
MoBe is offline
post #8 of 40 (permalink) Old 02-19-2011, 10:39 PM
Other Motorcycle: 1970 TR6R: SOLD....
Extra Motorcycle: 1999 Yamaha Virago 1100
The bit about kerosene is true, but...........the old trick was to drain a quart of the old oil and add a quart of kerosene, then run the engine for a while before draining it. Some folks used (and some still do) a quart of automatic transmission fluid for a small time before changing the oil. I too believe that modern oils have pretty much eliminated the need to use a flushing oil. However, if one drinks a quantity of castor oil..........there will be a considerable amount of "flushing" that will follow!!!
Sorry, the "village idiot" just couldn't let that one "pass" (pun intended): Jim
Jim Ballard
jimballard is online now
post #9 of 40 (permalink) Old 02-20-2011, 02:54 AM
RetroRod's Avatar
You had to bring that up didn't you Jim.
I recall from my childhood being given a medicine glass of castor oil to swallow as punishment for minor infractions of house rules. I can still taste it to this very day. Yuuuuuuuuuuuuk. RR
RetroRod is offline
post #10 of 40 (permalink) Old 02-20-2011, 06:44 AM Thread Starter
Multi weight detergent oils came into widespread use in the late sixties if I`m not mistaken.Based on that info alone the assumption would be that bikes of that era and the newer ones especially would not show signs of sludge buildup in the sludge tube,yet time after time we read on one thread or another that someone has taken the tube out of their crank only to find significant amounts of crud inside.How can this be? The most likely explanation in my opinion is the lack of adherence to the 1500 mile oil change interval by previous owners.
MoBe is offline
Flushing the brakes tshadow6 Air Cooled Twins Technical Talk 3 05-17-2010 09:55 AM
Flushing the Radiator smokinchaplain Daytona675 Forum 1 01-06-2010 02:18 PM
Flushing the radiator hooliganrider Speed Triple Forum 7 07-11-2007 07:25 PM
flushing the radiator moonshine Tiger Workshop (archive) 6 05-28-2007 01:10 PM
Flushing the Radiator woodrow Maintenance & Workshop Talk 19 03-31-2004 08:54 AM
