An even more anal way to ensure undamaged rocker spindle O rings - Page 4 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 11-22-2012, 08:27 AM   #31 (permalink)
Main Motorcycle: 1979 T140D Special
Other Motorcycle: 1978 T140E
Originally Posted by JohnA View Post
Not if you use some sort of a drift...
So you need two tools then (Triumph tool and a drift) and a hammer. Unfortunately I only have two arms, so will contintue to draw it in using the acorn nut
Another advantage of doing it this way is that you can draw it in really slowly so as to not damage the o-ring, which is what we are trying to achieve in the first place. I'm very suprised that the spindle cap can be removed from the spindle though. Are the T140 spindles constructed the same as the T120 spindles?
Cybersausage is offline   Reply With Quote
Old 11-22-2012, 10:07 AM   #32 (permalink)
Main Motorcycle: The one between my legs
Snakeoil's Avatar
Other Motorcycle: '76 Triumph T140V
Extra Motorcycle: Yes
John Healy over on the Britbike forum replied to a similar thread to what I have here, regarding these stinkin' o-rings. He says it is possible to get them installed properly and that the factory tool is useless. Here's a link to that thread to maintain continuity.
http://www.britbike.com/forums/ubbth...90&#Post464390
I'm probably going to try John's method.
Cyber - note that in John's reply, he says "tap" not pull in with the nut. John's a recognized expert on these bikes so if there were a better way, I think he'd be using it. Not trying to be right here, just trying to avoid problems for others.
My understanding is the cap is a press fit onto the spindle. A press fit is normally a pretty robust way of attaching something that is not in tension. I had to re-machine my caps because of a ham fisted mechanic using a metal hammer on them at some point and I the time, I thought they were one piece. It wasn't until I started to research the o-ring installation that I learned they were separate pieces.
regards,
Rob
regards,
Rob
Snakeoil is online now   Reply With Quote
Old 11-22-2012, 08:40 PM   #33 (permalink)
Snakeoil's Avatar
Tried John Healy's method with mixed results. Please see my resto thread for the rest of the story. I'm not done trying that method yet. I think it has the most promise for a undamage o-ring installation. It's just a matter of perfecting my technique.
regards,
Rob
Rocker spindle oilway Caulky Classic, Vintage & Veteran 6 10-14-2010 06:28 AM
Torqueing Rocker Spindle Dave W Classic, Vintage & Veteran 7 08-18-2010 06:57 AM
Replacing Rocker Spindle - T140V Dave W Classic, Vintage & Veteran 0 08-01-2010 11:18 AM
Changing rocker spindle O rings T120R (video) Plewsy Vintage Technical Tips & Tricks 15 03-04-2010 06:32 PM
Rocker spindle identification silverfish Classic, Vintage & Veteran 3 03-02-2010 12:40 AM
