750 splayed port head versus parallel port head - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 9 (permalink) Old 08-04-2010, 06:00 PM Thread Starter
Main Motorcycle: T140/T120/T100R/T100C/TR7
Other Motorcycle: W650, Scarabeo 500ie
Extra Motorcycle: Tiger Cub
As I recall the 750 Bonneville went to the parallel port head in 1979, and dropped the splayed port head then for the Bonneville.
Can someone tell me if the '79 thru '81 Bonneville head is essentially the same as the earlier single carb Tiger 750 heads.....and if the Tiger 750 single carb manifold will bolt right up to the '79 and later Bonneville head??
Basically what I'm wanting to do is swap out the tired Bings on my 1981 Bonnie for a simple single carb setup.
thanks,
fried okra
fried okra is offline
post #2 of 9 (permalink) Old 08-04-2010, 07:38 PM
Main Motorcycle: pre '68 Bonneville 750cc
Other Motorcycle: 86 Yamaha FJ1100
Extra Motorcycle: Custom mini-bike 165cc
I wish I could answer you question, but I did try to go with the opposite. I wanted to put a Bonneville manifold and two carbs on my 73 750 Tiger. Never figured it out. The Bonne manifolds were quite a bit different than my Tiger head.
TangoMike
If it's not leaking oil, there ain't none in it.
tangomike is offline
post #3 of 9 (permalink) Old 08-04-2010, 08:08 PM
Main Motorcycle: T120RT
KADUTZ's Avatar
Other Motorcycle: T140V,T140D,T140E,T140J
if you want a single carb bike get a TR7 head and associated parts. you will also need to change parts of the airbox assemblys if your bike is using stock airboxes. By your mention of bings I assume your bike is a '81 or later
TRIUMPH
"THE WORLDS PRE-EMINENT MOTORCYCLE"
KADUTZ is offline
post #4 of 9 (permalink) Old 08-04-2010, 08:35 PM Thread Starter
Yep, my bike is a dual carb Bing, 1981 model year.
What I was hoping is one of these kits would fit the existing parallel port head on the 1981 bike:
http://mapcycle.com/ProductDesc.aspx...-MIKUNI&key=it
fried okra
post #5 of 9 (permalink) Old 08-04-2010, 11:43 PM
KADUTZ's Avatar
Well I stopped telling you guys it wont work almost 30 years ago when a guy from florida stopped by the shop(in the chicago burbs) on his way to calif on T100 Triumph with a Horse saddle for a seat.
The ad says for TR7 Head ifin it would fit a T140E head it would say T140E head.
For what is worth it has been my experince the mikuni and amal mk2 carbs are able to use the same intake manifolds. While I'm not an expert on bings bet they use the same manifolds.
If you want to use the kit you showed you WILL NEED A TR7 HEAD.
TRIUMPH
KADUTZ is offline
post #6 of 9 (permalink) Old 08-05-2010, 05:25 AM
Main Motorcycle: T140 E
My 79 parts book (99-7102)
lists TR7 and T140E cylinder blocks as 71-4005 and being common between both bikes.
All I can suggest is to see what your bike's book says and if it's the same part number for the cylinder then a TR7 head should fit.
The twin carb head has steel stubs for a rubber mount tube for each carb, whereas the TR7 carb has a more conventional two stud flange
DAVE M is offline
post #7 of 9 (permalink) Old 08-05-2010, 08:50 AM Thread Starter
Thanks, guys....what lead me astray here was the ad referred to TR6 and TR7 models (no reference to the heads) and I harken back to the day when the TR6 was single carb and the TR7 was dual carb bike.
Anyway, single carb 750 heads are pretty rare I gather and my dual carb head has a fairly fresh rebuild.
I guess the primary options I've got are Amal MKll carbs or Mikunis on the existing steel tube stubs. I think "emission carb" when I think of the MKll's.
Any thoughts on the merits of MKll's, versus Mikunis, versus Bings on the parallel dual port heads??
fried okra
post #8 of 9 (permalink) Old 08-05-2010, 05:24 PM
Main Motorcycle: 1978 Triumph Bonneville
htown16's Avatar
I have the stock Mark II's on my 78 and think they are a decent carb. As far as being an "emission carb" it all depends on how they are jetted and what slide you use. There is a US set of specs and a European set. I don't know much about the Mikunis but my understanding is that they are very similar in design to the Mark II's, so it may come down to cost availablility.
Htown16, Houston, Texas
1978 T140E Bonneville, 1974 Trident, 1972 Commando, 1971 Commando
1974 Commando, 1970 BSA Thunderbolt, 2004 XL 1200R Sportster
Everything will be alright in the end.
If its not alright, its not the end.
htown16 is offline
post #9 of 9 (permalink) Old 08-06-2010, 04:46 AM
I have Bings on my TSX, Amal mk2s on my TSS and an Amal Mk1 on my TR65 and TR7T.
My comments on each are as follows but note the Mk1 is single and not operating as a pair like the others:
Bing - excellent mpg but needs careful setting up to achieve balancing, tickover, responsiveness etc
Mk2 - not good mpg but less tempremental than the Bing but less responsive
Mk1 - satisfactory mpg - crude, some may say, but consistently effective being less finnicky than then Bing and more responsive than the Mk2 with no flat spots
Bear in mind that the type of bike these are fitted to may effect their assessment. However, 'dem's me views'. Which would I go for ?
Bings- when properly set up, they're wonderful delivering smooth engine performance and,in these hard times, superior economy
meriden4ever is offline
Port Jeff BS CDickey Riders Group - NYC Area 11 05-08-2010 06:22 AM
WTH is this port? mjonesjr8 Daytona Deliberations 4 03-23-2010 06:11 PM
Who's off to Port 08 silversprinter Sprint Forum 2 07-07-2008 05:50 PM
Where is the OBDII port? krautfed Triumph SuperSports 2 04-28-2008 10:14 AM
AI question on the port danbike Air Cooled Twins Talk 7 04-07-2006 04:31 AM
