Can you clean the inside of rear brake drum ? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 5 (permalink) Old 05-06-2010, 07:11 AM Thread Starter
Main Motorcycle: 1969 T100S
Hello,
In the process of rebuilding the rear wheel.
Is it possible to clean the inside drum with some kind of cleaner or does it matter ?
I used some solvent but not much came off.
Thanks all any information.
Adam
ID:	24831   Click image for larger version
newtriumphowner is offline
post #2 of 5 (permalink) Old 05-06-2010, 08:12 AM
Main Motorcycle: '72 Bonneville
RetroRod's Avatar
Other Motorcycle: Suzuki GSX1400
Originally Posted by newtriumphowner View Post
Hello,
Adam
Hi Adam,
I looks like rust has developed inside the drum marring the finish made by the action of the brake shoe on the metal surface.
In some ways you are between the devil and the deep blue sea on this. You could scrape and wire brush the drum surface to the best ability and then reassemble. The mating surfaces will not be perfect initially and you may suffer from an ineffecient brake until the old shoes rebed themselves into the drum irregularities.
You may get the drum sand blasted and this will give better result for the remating of drum and old shoes.
You may have the drum machined, but it is rarely a good idea to use the old brake shoes, as they will be out of round and so braking effectiveness will be compromised.
The best fix would be to have the drum machined and fit new linings. HTH
You have enemies? Good. That means you've stood up for something, sometime in your life. (W S Churchill)
RetroRod is offline
post #3 of 5 (permalink) Old 05-06-2010, 12:08 PM
Main Motorcycle: Vincent
Marc Beaudry's Avatar
Other Motorcycle: trident
Extra Motorcycle: bonneville t120
glass bead blast to clean and then machine.
Marc Beaudry is offline
post #4 of 5 (permalink) Old 05-07-2010, 11:44 PM
Main Motorcycle: 1966 Thunderbird
Other Motorcycle: 1979 BMW R100RS
I'd tell you to get the drum powder coated. As part of the process, they blast the entire drum. A dead-clean drum is going to be your best bet for seating new brake shoes. And the powder coat takes very high heat easily.
The GABMA newsletter. What's on the back of your toilet?
http://www.gabma.us/
GABMA is offline
post #5 of 5 (permalink) Old 05-09-2010, 05:09 PM Thread Starter
Thanks for everyones feedback. I have an appointment to bead blast the pieces and powder coat the outsides.
Thanks Again !
what size clutch and brake cable do i need? pics inside... sbpark Air Cooled Twins Technical Talk 11 03-08-2010 06:30 PM
How do you remove the nut on the conical drum brake housing Landshark Classic, Vintage & Veteran 1 07-21-2009 04:30 PM
'67 Drum Brake Performance? Seattle73 Classic, Vintage & Veteran 7 07-08-2009 04:16 PM
A trip to the Triumph dealer (brake and clutch commentary inside) SR1 Sprint Forum 4 12-15-2005 09:11 PM
drum brake question TheBondoBandit Classic, Vintage & Veteran 13 06-06-2005 10:26 PM
