Magneto Sprocket/Gear Removal - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 16 (permalink) Old 03-21-2010, 01:05 AM Thread Starter
Main Motorcycle: 1978 T140V
blue-triumph's Avatar
Other Motorcycle: 1965 T120C
Extra Motorcycle: 1968 T100 Trackmaster
What tool is required to remove the magneto sprocket from a K2F?
blue-triumph is offline
post #2 of 16 (permalink) Old 03-21-2010, 07:53 PM
Main Motorcycle: 5T 1958 SPEED TWIN
pre unit Thruxton's Avatar
Other Motorcycle: 1959 Triumph Bonneville
Send a message via Skype™ to pre unit Thruxton
Please rephrase your question - be careful you can cause a lot of expensive damage.
14mm - 9/16"
pre unit Thruxton is offline
post #3 of 16 (permalink) Old 03-21-2010, 07:56 PM
Main Motorcycle: 1958 Norton Nomad
Other Motorcycle: 2000 Triumph TBS
You will need a puller and some bolts that screw into the gear. Be careful with the puller on the shaft of the magneto as you can damage it. It is a taper fit.
Greaser is offline
post #4 of 16 (permalink) Old 03-21-2010, 09:40 PM Thread Starter
I was not specific. I am moving a few magnetos around, and the one I was asking the question about is actually a K2FC.
The gear appears to be fiber with a metal center. The metal center does not have any threaded holes, but rather what may be something like rivets. The center hole in the gear appears to be threaded.
So one of my questions is whether the gear is pressed on or threaded. And the second part is whether a specific tool exists that treads into the center hole for removing the gear, or if some othe method is used.
Thank you.
post #5 of 16 (permalink) Old 03-21-2010, 10:59 PM
Main Motorcycle: 1959 Triumph TR6
Other Motorcycle: 2003 HD Road King Police
Magneto wheel. Unscrew the securing nut and screw into the gear centre the withdrawal tool DA50/f which is supplied with the toolkit.. When the tool is in position, tighten the centre bolt and the gear will be withdrawn from the shaft. The automatic timing device is released by unscrewing the central bolt which has a self-extracting thread.
From manual no.17 engine 0945 and D101 onwards Sept 1956
Red1959 is offline
post #6 of 16 (permalink) Old 03-21-2010, 11:34 PM Thread Starter
OK. That is what I understood from reading the manual, but I have had difficulty finding the tool, so I thought perhaps I misunderstood. I will see if I can track down the tool.
Thanks.
post #7 of 16 (permalink) Old 03-22-2010, 01:32 AM
There are two type of mags - auto advance and manual. Which one do you have?
They are both different but the same if that makes sense. Once the bolt or nut is removed, you need to remove the fiber gear which is tapered so you need a puller to remove it off the shaft. there are other ways to remove it but for now see if you can find a puller. Under no circumstances hit the nut or bolt with a hammer to release it you may damage your magneto and the thread etc.
post #8 of 16 (permalink) Old 03-22-2010, 10:14 AM
Legend
I have one of those "cast butter" fibre gears with several broken teeth sitting on the shelf - a testimony to rookie stupidity. I replaced it with an aluminum one.
The tapered fit setup is the same as with the ignition rotor; side-force tapping should free it off.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
GrandPaulZ is offline
post #9 of 16 (permalink) Old 03-22-2010, 12:26 PM Thread Starter
I have both magneto types. I was able to remove the auto advance without any problem. The mag I am presently working on is the non auto advance. I will check with Rabers in San Jose, they may have the tool. If anyone knows of a U.S tool source that has this puller, I would appreciate the name. Thanks all of your responses.
post #10 of 16 (permalink) Old 03-22-2010, 08:12 PM
Why two types? Which one is correct for your bike? (The method of timing varies for both theses gears) Is the magneto fitted in place? This may seem stupid. Remove the nut, loosen the magneto on the back of the casing just a little about 3-4mm. replace the nut just until the thread is just about to come out past the nut.
Remember if you hit the nut with a mallet you are moving the armature backwards in its casing and can cause damage to the internals of the slip ring etc. That is why you will need to loosen the magneto off the back of the casing; you can now pack a wide flat wedge to either side of the gear between the timing case and the gear. With this in place you can now give the centre nut a sharp tap with a mallet and this should loosen the tapered end off the shaft. The gear will now slid off.
What bike do you have?
gear selector rod removal? fraggle69 T3 Sport / Touring Forum 5 06-26-2009 06:01 PM
Gearbox Seal behind the secondary gear sprocket Aussie Dave Classic, Vintage & Veteran 3 05-30-2009 09:56 PM
joe hunt magneto vs lucas magneto preunit13 Classic, Vintage & Veteran 20 09-06-2008 08:03 PM
Removal of rear sprocket NeonBlueS3 Speed Triple Forum 9 09-08-2006 04:59 PM
Magneto Sprocket Extractor COOPERS Classic, Vintage & Veteran 1 11-28-2005 05:43 PM
